Question about ASUS P4S800D-X Motherboard
Did my motherboard fail?
Computer was up and running fine for a couple of weeks and then crashed. was completely non responsive and had shut down manually. When turned back on it does absolutely nothing, I can't start in safe mode, access start up utility, or bios. No signal is being sent to the monitor at all. Help!
  • 37 Answers
1. When you switch on the supply, and press the power button on, do you see any LED activity - thus indicating power may be running to the board? If not, it could point to a possible supply failure, and so you should check the internal fuse at the rear of the supply.
2. Do you have more than one memory module? If so, try running the computer with only one memory module at a time, thus eliminating the possibility of a single RAM module failing the entire system.
3. Is the CPU seated correctly, could it have become dislodged from its mountings? Heatsink fans (HSF's) are quite heavy, and when they force a cpu to become disconnected, you would not be able to boot in that case too.
Be sure to consider ESD protection when inside your computer, and at the very least, ground your body by touching with both hands a gas pipe, etc, that is connected to ground, before handling any memory / cpu parts.
Good luck,
Erik.
Posted on May 26, 2008
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
New PC shutting down with MSI K9A2 mother board
this is a problem complexing situation because here are involved more than one device that causing this, if you have time and parts to experiment is a good think, you have to take out from your board cpu ram and vga-s and put in their place a second component(take from your friend or if you know that guy in service maybe halping you with parts so even him is taking experience of this situations). after testing your Mb with second components if it working fine no shut downs no crahes, then problem is in one of other components, try it taking out second parts one by one eny time, replacing with your components. begin with vga(or vga-s if you have more than one but is better to put it and prove them one by one to diagnose if their have problems) after doing this and you didnt finded problem in vga/s let your part in place and change second ram taht you puted with yours(if have more than a module prove it one by one each time reboting system after each one.) if even in your ram you dont have problems, so change cpu/s. one of this components without dubt is faulty.
if problem resolved and you dont have more problems and didnt find a faulty component and your pc is working fine so it was a miss making.
try all experiments with mother board outside case. some time shrt circuit of Mb with case is causing problem, after try it in case if you dont finded problems, in any way that i told you up.
Apr 07, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Asus a8n sli deluxe not powering up
do you have 2 sticks of ram in the pc?
if so try it with one in and do this with both
as in boot it with a single ram stick and try to determine if its a faulty ram stick
also if you can try another power sup unit
please let me know how you get on
Mar 22, 2008 | ASUS A8N-SLI Motherboard
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Dec 12, 2007 | Intel D945GNT Motherboard
Evo N610c Laptop - auto shutdown?
If you had the adapter checked out, then it has to be the power input to the motherboard (where you plug the adapter in). I have one of these laptop's as well, but my problem is that the battery is completely drained and won't change. Never the less, you might be able to find a replacement motherboard from ebay for fairly cheap.
Nov 13, 2007 | HP Compaq Evo n610c Notebook
INOVIX IMP-1112 MP3 crashing my computer.
sounds like bad news - if the flash (update to firmware) failed during update, the item is more than likely dead. Warranty return possible? Can you try another usb device on that same pc? just to verify the usb ports are working properly and supplying proper power to the devices.
Aug 26, 2007 | Inovix iMP-20 MP3 Player
ASUS P4S800D-X Motherboard Logo
204 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
