Question about Refrigerators
How many watts is kelvinator ktd240mn? - Refrigerators
Where is the fuse location for Kelvinator wall oven model # R30-1
Kelvinator Oven Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/electrolux-kelvinator/oven/
How to light an oven of kelvinator KCL86GSC gas co. Kelvinator ... Replacing thefuses on my kelvinator stove model H
Nov 15, 2015 | Ovens
LED Lighting
Not really no. There are kits available but all to often there are laws and standards for vehicles in which the conversions do not abide by. Make sure you research what is legal before attempting such, usually is not worth it.
Dec 08, 2014 | 2004 Lincoln Navigator
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
Why kelvinator stop in india in 1999
I don't believe that fixya.com is responsible for kelvinator being stopped in India. You should try and locate the creators of kelvinator to see why they stopped it.
Oct 16, 2013 | Computers & Internet
Wattage use
Your calculations is correct - 220 X 0.7 = 154 watts.
If your fridge only runs on 220 volts then you need solar panels that charge 12 volt lead acid batteries and then use a inverter to convert 12 volts DC to 220 volts AC.
Jan 13, 2012 | Kelvinator Refrigerators
Do I need a bulb with this same wattage,?
18 watt should work fine, but give less light.
Dec 14, 2011 | Tensor Home
Kelvinator model N641n
I have a kelvinator refrigerator, top-mount type model # SKNT 16E.
220V, 1-phase, Defrost amps 1.9, Watts 575,
Gross/Liters 453/396
I have replaced new door gasket.
Freezer gasket is in very condition.
Compressor drawing 3.15amps.
  1. Question is Compressor is working 8 minutes and remains off for 3 minutes.This cycle is happening from some days.Thermostat and timers seem to be ok. Do i need to change Overload cut-out at the compressor or not....please suggest.
masood
masbimed@yahoo.com
Feb 18, 2009 | Refrigerators
I need to know the power use / wattage of the kelvinator opal fridge - i think its a 200lt
You can figure the power usage by taking the voltage x Amperage, That will give you watts. EXAMPLE 120 x 6 = 720 watts . there should be a data plate inside the fridge giving you the full load amps. Which is everything that draws amps on at the same time. Hope this helps. Any questions get back with me and I can help more.
Dec 07, 2008 | Refrigerators
Refrigerators Logo
246 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
