Question about Acer Aspire 5500 5570-2609 Laptop
Acer 5000 laptop
I instaled a new screen and inverter screen still black. Works with external monitor and I tried the (fn 5 key)still dosen't work also took battery out to restart.
Thanks for your help
  • bmarter May 26, 2008
    i replaced the screen because it was cracked. The old one is now black also.
  • bmarter May 29, 2008
    found out I bought a bad inverter
  • 100 Answers
Could you write down the models of the new and old screen to check for compatibility?
Posted on May 26, 2008
Monitor is dark. how to fix?
Walt, hold the Fn key down again, and tap once more on the Acer, F5, Display Toggle-Over key.
There are at least 3 display options available;
1) Internal display of laptop ONLY
2) Internal display of laptop AND external display
3) External display ONLY.
Were you just using the external display for more 'display real estate room', or was/is there a problem with the internal display of the laptop?
Was no problem? Is now? Even when using the guidance stated above for the Fn and F5 key?
Then if your laptop uses a CCFL for a Backlight, it also uses a screen Inverter. Screen Inverter is bad.
If it doesn't use CCFL/s for a backlight, and uses LED backlighting, replace the LCD screen.
The LED backlighting is incorporated in the LCD screen assembly, and you ain't replacing it.
Replace the entire LCD screen.
Post the laptop manufacturer name, and model number in a Comment. Model number is on Bottom of laptop.
Try to hurry as I'm going to a meeting with the head of General Motors, (Obama), and later with Bill Gates.
OH I'M JUST KIDDING!
Regards,
joecoolvette
Nov 14, 2012 | Computers & Internet
Acer aspire as5052an wxmi
Does it seem like the laptop booted up except the screen is black? if so, try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 08, 2012 | Acer Computers & Internet
Black screen w/ faint image
It sounds like the inverter to me.
Mar 31, 2012 | Computers & Internet
Cannot get the Fn-F5 to work on Acer AspireOne
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Nov 10, 2011 | Acer Aspire One PC Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 6530G black screen
There's no point getting a crisis program if you cannot see the screen in the first place.
The problem could be anything from a faulty graphics, faulty motherboard or loose cable or inverter board.
To test this connect an external monitor to the laptop and use the keyboard toggle to switch screens (hold down Fn and press the F key that has a monitor icon on it)
If the external monitor has a display on it then the problem is the inverter, inverter cable or the screen itself which if faulty.
If there is no display on the external monitor you maybe looking at a new laptop.
If you have no external monitor to test then look very close at the laptop screen, if you can just make out an image then its the inverter.
Post back if you require any more assistance.
Regards.
Sep 02, 2009 | Acer Computers & Internet
Can't switch to external monitor using Fn5
On my 5000 I could use the fn f5 key or the eManager / ePower whatever program to set internal external or both. Also turns on off presentation device
Feb 28, 2009 | Acer Aspire 5000 Notebook
Acer laptop monitor black
if you dont have signal on your laptop screen, could be:
Broken LCD, Bad inverter, or bad graphics card.
Sep 23, 2008 | Acer Aspire 5100 Notebook
Acer aspire 3050 black
refer to ur user manual to see which key for brightness e.g.fn+f 9
(reduce brightness)if havnt got one can easily download one of net.try to swich screen to monitor.connect external moniter and press fn+f 5.(refer to manual maybe different key)
press down and release screen lid button see if any response.if all fail need to disassemble.
remove screw in about middle of pc underneath.this ia retainer screw for key board.remove screws dirrectly behind screen to remove plate with buttons.then can get access to keyboard and lift away (do not disconnect it just rest it on screen or front of pc )check cables from mother board to screen.check inverter.
all these are worth checking but initially sounds like inverter faulty.
Mar 05, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
