Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8520 phone had solid green light this morning and wouldn't turn on or charge. Took battery out and eventually managed to get it charged but now keep getting error msg (uncaught exception: index 4>=4) when turn on phone and when try typing message on keyboard, after first few letters everything else is a n and then freezes and wont do anythin else or turn off so have to take battery out again. The phone is only 1 week old?
  • 86 Answers
SOURCE: Battery won't charge in phone.
Have you tried a different charger? If not I would suggest stopping by one of your cellular providers stores and having them plug it in to see if it works.
Posted on Mar 27, 2009
label_chick
  • 407 Answers
SOURCE: blackberry reset
try to reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys -
Posted on Jun 01, 2009
SOURCE: RIM Blackberry Curve 8310 stopped working
Sounds like you have a short in the connector plates inside the phone. Has the phone been exposed to water or lots of humidity? This is a problem with some phones. Look inside the phone and see if the 4 gold pins sticking out seem corroded. If it's not nice and shiny, then moisture could of played a roll in your phone breaking down. Or if you have dust or a thin layer of powdery substance that would do it too. Since you've tried a new battery and charged it a few different ways, my bet is it's a connector malfunction and you should take it back to your service center. Had the same problem when the Razors first came out. mmw2222
Posted on Aug 20, 2009
  • 5 Answers
SOURCE: Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
fleshgear
  • 541 Answers
SOURCE: my blackberry curve 8310 was dead this morning
I hope battery is working fine,so try connecting this phone using USB cable to computer, and check wheather computer is recognising your device.still if its not working then you can go to nearest service center.
Posted on Oct 30, 2009
BB curve 8520 will not start
Good chance the unit is either broken and not allowing the Operating System (OS) to run. Next step would be to download/install Blackberry Desktop Manager (for this version of Blackberry) from the Blackberry website. Connect the Blackberry to the PC running Desktop Manager and see if the Desktop Manager can connect to the Blackberry. If yes, you could try to update the OS.
Jan 05, 2014 | RIM BlackBerry Cell Phones
Blackberry curve just reboots doesnt turn on
Buddy Just Download Destop Manager Of Black berry and connect to pc and format every thing or upgrade the software it is because of any application ( Corrupted) Just try and replay
Nov 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
Blackberry curve 8520 wont turn on, no red light wont charge or do nothing when the usb is inserted
maybe a bad cord. if it charges normal on the charger then it needs to be setup so it will charge thru the usb
Jul 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
May 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry phone [ model-8520 curve] is showing error 523.plz tell us what to do....
first thing is to do a battery pull ..........if that doersnt work use desktop manager to reload the software ....if DM cannot load software use a program called jl_commander to wipe the device and reload software with DM
I plugged the BB on the charge 4 an hour!now it cant turn on
hello.
The solution to your phone problem is this, fix up your battery back to your phone then plunge back your phone to AC (electric) then allow the phone to booth up the phone will show sign of charging after this unplugged the phone then turn it ON you will be able to make use of your phone.
Thanks for using fixya.
Good luck.
Mar 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
My 8520 curve just shut off and will not power up. Full charge, phone 1 week old
My Blackberry 8520 just shut itself down and when I try to turn it back on nothing happens but when I put it into the wall charger the red LED light comes on and a charging symbol but still doesnt switch on.
Ive tried of mulitiple occasions taking out the battery and rebooting it but still no sign of any life?
Any Idea's?
Feb 12, 2010 | RIM BlackBerry Curve 8520 Smartphone
I need unlock code for my blackberry 8520 curve
How To Unlock a Blackberry Curve 8520 1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card.
2. Using the menu go to Settings Menu -> SIM card and press select.
3. While holding the SHIFT key, type mepd.
4. You should now see the five locking categories listed.
5. While holding the SHIFT KEY, type mep2.
6. Release the shift key.
7. You will now be prompted to enter the Network MEP code.
8. Enter the Unlock Code.
9. Enter Return/Enter.
10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
Blackberry curve wont power on. Worked fine yesterday. Put on charger last night. This morning phone was off and wont power on. Took battery out, then but back in still wont turn on
First charge your mobile for atleast 1 hour,and switch it ON you to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. To perform a clean installation of the BlackBerry Device Software using Blackberry Desktop Manager 4.5 to 5.0, perform the following steps:- 1) Open BlackBerry Desktop Manager. 2) Click Help. 3) Select About Desktop Manager. 4) Click the Device Software tab. 5) Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
Nov 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
436 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
