Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice dispenser Can anyone tell me where to find an "exploded" diagram of the flapper/gate that is above the ice chute? It has come fact, a piece was on the floor! The ice can't dispense because the flap won't open. Any advice?
  • Anonymous Jun 11, 2008
    my ice flap does not close all the way and causes the ice to frost over and all freeze as one block
  • htrabin Jul 01, 2008
    No Ice is being made. The switch is slid to the ON position and I see a small red light blinking twice then pause then twice again.
When mine wasn't making ice i had to thaw out the hose that leads to the ice maker with a hair dryer. I guess that if it doesn't have to make ice for a long enough time that the hose freezes solid.
Posted on Jul 02, 2008
  • 868 Answers
Replace the "fountain ice /door kit" ,it will come with every thing you need. Please rate this !
Posted on Jun 12, 2008
Can the flapper for ice be replaced?
Refrigerator model number? ice chute door replacement
26177815-rm0wrikgpdq1hfoxb3io2p34-3-0.jpg need your model number for the correct part Dispenser Door 8201756
Apr 27, 2016 | Refrigerators
How to remove the dispenser panel? PLHS269ZDBB
Check and ensure that the rod that hold these flapper is fitted properly in its slots.
Aug 03, 2014 | Frigidaire Professional Series PHS68EJSB...
Ice Dispenser keeps getting frosted over and not dispensing ice
The problem your having is that the door in the dispenser chute isn't closing completly and warm air is coming in, clashing with the freezer and the moisture in the warm air freezes and collects right there in the chute causing the ice build up. The more common parts that may cause this is the door flapper being bad or damaged, flapper soleniod, which helps the flapper doofr get a good seal, and electronic board on the dispenser itself.
May 24, 2012 | GE Refrigerators
I have a GE SS25ksta side by side refriderator. The ice maker makes ice, but the chute jams without fail. It is almost as if the ice doesn't weigh enough to push open the flapper arm at the bottom of the...
there's a solenoid that opens and closes the shute or the flapper.the part number is WR62X10055 and it's around 25 dollars.check around the plastic frame that holds this section of the dispenser in place,i'm pretty sure the frame pops off,you might need a putty knife or thin screw driver to pop it off,then you can get at the rest of the parts to change out the's self explanatory and easy to change it out once you pop off the outside frame piece
Jan 16, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser
make sure that the flap is sitting in properly. if it is and problem still happens then i'd say that its a design fault
Nov 10, 2007 | Maytag MSD2756GES Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
124 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
