Question about Hitachi 57GWX20B 57" Rear Projection Television
Picture dark...can barely make out people hitachi 57gwxz20b
  • 1,583 Answers
Did this happen suddenly, or has the picture been dimming gradually?
If it was a sudden onset, I would first suspect the high voltage terminal/focus divider block. The focus divider in many sets also produces the "screen" voltage, which has an effect on the brightness of the picture. Often focus dividers will crack when they fail, so you may be able to spot a problem with this part by visual inspection. Other possibilities include an incorrect (failing) supply voltage to the picture tube boards (G1, G2, or driver transistor power).
Gradual dimming (other than problems with degrading components in the power supply):
Do you have a smoker in the house? The tar in tobacco smoke is attracted to the high voltage on picture tubes. You may need to clean off all of the optical components. I have found that window cleaner sprayed on a soft paper towel works for this. Do not spray the cleaner inside the set, and don't make the towel dripping wet with the cleaner! You risk serious damage to the electronics if you do. Avoid scrubbing - you don't want to scratch anything or push it out of alignment. Just keep wiping gently and let the window cleaner do its work. If tar buildup is the problem and it is as far gone as you describe, you will probably use up quite a few towels and a sizable fraction of the window cleaner bottle before all three picture tubes are clean. Don't do more than dust off the sides of the tubes - it's the face that needs cleaning, and window cleaner is bad news
Another possibility is broken-down CRT cooling fluid. (This is low probability - you would probably have noticed the colors going to an ugly yellowish brown long before it went dim.) When you look at the top of the three picture tubes, you should be able to see that they are red, green or blue. If the colors are quite dark, dull or muddy-looking, the CRT coolant has gone bad. It is possible to change it, but be warned that you must not let any drip into the electronics. Broken-down coolant can conduct high-voltage electricity, and the results are disastrous - I've seen a power supply board ruined by the stuff.
Posted on Oct 23, 2010
Our tv is very dark. The picture can barely be seen. How do we fix that?
how many hours did your lamp work? perhaps the lamp need to be replaced.
if it was new lamp. the other two possible reason is light tunnel and ass relay.
no matter for what reason, you need to clean it for so old model tv
Oct 21, 2014 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Apr 08, 2011 | Hitachi Televison & Video
Screen too dark, no setting can fix.
Sometimes the Screen (G2) control needs to be adjusted. This control is an internal adjustment that should only be attempted by a qualified person however.
May 02, 2009 | Hitachi 32UX01S TV
Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Mar 12, 2009 | Televison & Video
HitachI HD DIGITAL TV 53"
Good Day;
For dark picture check RP41 heater circuit, 1.5 ohm, may have changed value & clean spark gaps. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Dark LCD Screens and no flash
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Feb 06, 2008 | Canon PowerShot A70 Digital Camera
Problem with hitachi projection television
can you open the front and see if any liquid is spilled in front?
Jan 18, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi Ultravision Digital TV dark picture
Looks like
1. A Cold solder in the Video Output stage power supply.
2. A bad Electrolytic Capacitor in the above Video Output stage.
I generally do not waste time in attempting to locate faulty capacitors. There will be only 6-8 pf them in the above stage / section,m and the klot of them would collectivelyt not cost more than 3-4 $ equivalent, in india. Just blindly replace the lot, and the set is ready in 30 mins.
Dunno how much they will cost in your country. Try to look for a 100mfd, 160V Capacitor. Close your eyes and replace. generally does the trick.
Nov 13, 2007 | Hitachi 32UDX10S 32" TV
Problem with picture it is very dark
hi,
Just a guess,under the power button, inside the the flip[ down cover is a light dimmer,you can turn this on and off,in advanced settings under video,a flash light will trigger the sensor to see if it works the dimmer,if not it could be that circuit or your power supply needs work,I hope this helps!
Dec 01, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 57GWX20B 57" Rear Projection Television Logo
73 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
