Question about Ovens
I need wiring schmatics for a 1950s-1960s GE double range electric stove my grandma has been using up to this day. It's still in awesome condition, but one of the coil burners is not working. Any help would be greatly appreciated! - Connie
  • Kelly
    Kelly Oct 02, 2010
    Hi Connie. I think we can find you a coil burner but... we need to have a model number to help you find it. Would you look around the oven for a model number please so I can help you. FYI all Fixya Experts are going to ask for this same information. If it is not in the original post... each one of us has to ask you. for a model number. It does not go public.
    Thanks
    Kelly
  • connie_weldo Oct 02, 2010
    We think it might have to do with the wiring. However, here's the model# J408TIWH-15.2. Thank you Kelly!
  • Ovens Master
  • 3,740 Answers
Hi again Connie.
The model number did not cross so I am trying a differnt route to see if this helps.
It is common on an older range to have the wires degrade where the range wiring connects to the burner. Usually only one wire fails and it is easily spotted once you remove the burner.
I think you can find your surface burners here.
http://www.repairclinic.com/GE-Range-Stove-Oven-Parts?s=b3a13c42&z=50
NOTE the ones that are kits.... I would recommend that direction simply because it has all the stuff you would need to fix existing wiring problems.
This is ONE kit example for and 8 inch burner:
http://www.repairclinic.com/SSPartDetail.aspx?s=b3a13c42i2573&PartID=2573
This is ONE kit example for and 6 inch burner:
I am not 100% sure these are the burners you need but if you can compare what you have vs these examples or the rest of them in the first link (262 items listed) not so many surface elements..... I am pretty sure even the average handyperson can get this going.... Just make sure to REMOVE all power from the unit when dealing with the burners.
Let me know if you need more help or... see if you can sort out why the model number you passed did not cross and pass that here again.
Thanks,
Kelly
( I will not be on for several hours after this post but will be back later )
Posted on Oct 02, 2010
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
No stove wires hooked up to neutral
The older electric hookups for ranges used only the 2 hot wires and a ground. Somewhere on the range the neutral and the ground should be connected together. This connection is no longer accepted by the National Electrical Code, but no one is going to force you to change the wiring unless you change the range.
Where is the ground wire attached? Some ranges had a metal jumper to connect the neutral to the ground. Your oven element is 240 volt only. It does not need a neutral. The ground/neutral wire is for some of the controls and the clock.
Aug 13, 2015 | Kenmore Stove / Oven / Range Bake Element...
I will soon purchase a GE Double Oven (no stove top). I need to know what amperage I need to wire my kitchen for. 30? 40? 50? thanks.
A full upright range including 4 hotplates, oven and grill elements is generally rated about 8.0 to 10.0 kilowatts. The normal circuit in Aust. is a 32 amp circuit. Check the kilowatt rating of the double oven but I don't think it will be any higher than 6.0 kilowatt. If so the 30 amp circuit will be fine.
Feb 18, 2011 | GE Profile JTP56 Electric Double Oven
Oven wont come on F8 error on screen
Depending on the brand. GE would be the erc or electronic range control. If any other brand the lock assembly on the self clean has gone bad and will need to be replaced. Hope this helps. Rick
Mar 09, 2010 | Stoves 720EF Electric Double Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 | GE Ovens
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
129 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
