How to install my router for wireless internet on my laptop.
  • 570 Answers
1. Purchase a wireless router that fits your needs and price range.
2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
7. Click on "Properties."
8. Select the "Wireless Networks" tab.
9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
10. Click on "Configure" when you see your network's SSID in the "Available Networks."
11. Enter your network's SSID and WEP key.
12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Thanks.
Have great day.
Posted on Oct 02, 2010
Wireless antenna or wireless router
Did your ISP Boingo supply you with a DSL or cable modem with a built-in wireless router? If only a DSL or cable modem is supplied and you wish to connect to the Internet by wireless then you need to connect a wireless router to this DSL or cable modem.
You can connect to the Internet using a LAN cable from your laptop to the DSL or cable modem.
If your laptop as a built-in wireless card you can to the Internet via the wireless router.
If you laptop does not have a built-in wireless card then you can install a PCMCIA wireless card into the card slot of your laptop to the Internet via a wireless connection.
Nov 01, 2012 | Toshiba Computers & Internet
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
I cant get this sylvania 7 smartbook , model # synet07wicv to get internet.
Dec 25, 2011 | Sylvania G-Netbook
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this "laptop" to enable getting wireless connection of internet?
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
Jul 29, 2011 | Dell Inspiron 5100 Laptop
Have a desktop with cable internet - installed router and added my laptop to wireless - it picked up the signal and connected and put in password no problem. Tried to do same with my cousins laptop from...
You would connect a laptop from Canada the same way as one from the US. You want to make sure the wireless card is turned on and check for wireless networks. Once you have found your network select it make sure you type the password correctly.
Dec 30, 2010 | Belkin F5D7234-4 Router
Can't get wireless to work on laptop
You may use the System restore utility on windows by going to all programs then Accessories... Open system Tools and then System Restore. You may resotre your system to an earlier time, time when you are still able to connect to your router wirelessly.
^_^
Jul 16, 2010 | Dell Inspiron E1505 Notebook
Have laptop with internet but want to share it with xboxs
Yes, simply set up laptop as a mini server (Wireless) at the other end of the house (Where the Xboxes are) and ensure it has the WEP key installed when asked to access the router / internet. Buy a router adapter for each Xbox 360 that connects to them in the RJ45 slot and connect thru the laptop agian using the WEP key that you should have installed in the Router.
Mar 05, 2010 | Computers & Internet
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
Can not use Internet with new Linksys rangeplus wireless router
Okay chances are your 2wire's ip address is conflicting with your router's ip address. Set up your router to use 192.168.2.1. Save the settings then everything should work for you.
Jun 14, 2008 | Computers & Internet
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
