Question about Ovens
I have a Jenn-Air oven 8114P734-60 and the only part of it that works is the stove top. The problems began with the push buttons on the oven - some numbers worked (1,2,3,6 and 7) - no numbers on the right half of the oven would work, yet the Bake button to the further right worked. Then the oven would just make this crazy beeping - without anyone touching it, over and over again. Then tonight the oven stopped working. I get a message on it,F1-7. I called the service number that appeared on the oven but that was no help. I turned off the circuit breaker for a long while, about an hour, but it didn't matter - the oven still does nothing. What do I do?
  • 833 Answers
SOURCE: Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Posted on Nov 28, 2008
  • 547 Answers
SOURCE: oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Posted on Aug 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Posted on Aug 30, 2009
SOURCE: Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Posted on Aug 31, 2009
SOURCE: My Jenn-air oven won't turn on. It's model number
My Jenn Air 1995 wall oven was working fine until one day the oven and the oven gas burner did not turn ON. I had electricty (make sure you did not trip a breaker) since my front panel LCD and clock was OK. I had a good gas supply.
My oven is an "pilot-less" oven, it uses an electric igniter. Although the "ignitor" was "glowing red hot", the problem is that the gas valve depend on a certain amount of current. If you have a 120V house system, I think the valve needs 3.3 to 3.6 amps to turn on. The current flows through the igniter and then through the valve, as in a same path, like water. So you need an AMP meter to check proper current flow. I read 2.4 amps. I replaced the "glowing red hot" igniter with a new one, Vo"la it was fixed.
Bottom line if you have the oven plugged in OK and you see some life (clock), and you have the gas turned on, most likely the igniter is bad. Second choice would be the oven's thermostat (the temp knob that you turn, say to 350F), or it could be the gas valve.
All three are in same current circuit. The igniter gets the most abuse so I would start there first -good luck!
Posted on Dec 18, 2009
Jenn-air oven not responding
Get out the owners manual and there are some symptoms solutions
If you can't find the answer there there is a customer service support line telephone number. You can give them the model number of the stove and he'll give you a method to find out what's wrong it may just be a fuse
Nov 26, 2014 | Jenn-Air Ovens
I need to know to set the tempature on my jenn air range oven this is a push button ove n
i decided not to try to fix it i think i would have to buy a complete panel, to fix it that would cost nearly as much as a new stove
Jan 29, 2010 | Ovens
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Ovens Logo
269 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
