Question about Acer Aspire 5050 Notebook
Acer aspire 5050-3371 Ihave the 2 mhz single core cpu . I just nocticed amd has come out with amobile triple core with a lower tdp wouls my laptop support this?
    Guru:
  • 1,082 Answers
Maybe, but swapping CPUs in desktops is iffy, in laptops it is a guru challenge. Sometimes they are solder in so replacement is almost impossible.
More speed generally won't help as much as more memory and a faster (solid state) disk. I doubt you'd even notice a faster CPU unless you are doing video editing.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Posted on Oct 01, 2010
Testimonial: "appreciate the quick answer I'm already up to 4 gigs ram and switched to a fairly light version of linux to pick up speed and stability."
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Jan 12, 2013 | Acer Aspire Computers & Internet
Do you help in recoverying stollen acer computers? serial number EXDXF0100302315B552000
hi,
in that case you have to contact your laptops manufacturer (ACER) to report the incident and provide the serial number of the laptop.
Mar 30, 2011 | Acer Aspire AS7551G-6477 NoteBook AMD...
Does my acer 5535 have a webcam
According to the specs. it does not have a WEBcam.
This is the specs.
Aspire 5535 Series Specifications
Part Number: Aspire5535 Aspire 5535
Feature Description Part Number Varies by specifications Processor / Speed AMD Turion™ X2 Ultra dual-core mobile technology ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1 MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology. Core Logic Chipset AMD M780G Chipset. System Bus Speed 667 MHz. RAM / Max RAM Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules. Video Subsystem ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0. LCD Properties Display 15.6" HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time. Hard Disk Drive 120/160/250/320 GB or larger hard disk drive. Optical Drive 8X DVD-Super Multi double-layer. Battery, Primary 48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use. Sound Subsystem Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone. PCCard Support 1 ExpressCard™/54 slot. Pointing Device Touchpad Peripheral Subsystem ExpressCard™/54 slot.
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model) Dimensions / Weight 15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack. AC Power 100-240V AC AutoSensing Adapt
Dec 23, 2010 | Acer Computers & Internet
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Sorry.
Oct 18, 2010 | Acer Aspire 5720 Notebook
My Acer Aspire 5520G will not play a Blu Ray disk. It keeps telling me that I need a critical update to the Acer Archade DVD playing software. When I click on the update button it comes back with a message...
from these derived specs You do not have a blue ray drive installed in this you have a DVD drive so of course a blue ray would not play in this unit. Specs are below from acer
CPU: AMD Turion 64 X2 TL-58, 1900 MHz [(9.5 x 200), L1 cache 64 KB/core, L2 cache 512 KB/core - dual-core, 64 bit support]
Motherboard Chipset: nVidia nForce 7000M-610M (southbridge), AMD Hammer DDR 2 IMC (northbridge)
BIOS Type: Phoenix
RAM: 2048 MB [667 MHz DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)]
Video adapter: nVidia GeForce 8600M GS, 512 MB GDDR2 [128 bit, core clock 600 MHz, shader clock 1200 MHz, memory clock 700 MHz - support for DirectX 10]
Monitor: Acer CrystalBrite 15.4" LCD (LG Philips), WXGA [8 ms/220-nit, currently running at 1280x800@60Hz] - HDTV capable
Audio: Realtek ALC268 @ nVidia MCP67/68 - High Definition Audio controller; Dolby Sound; audio jacks (on the front side): headphones, microphone, S/PDIF
Networking: nVidia MCP67/68; (wireless) Atheros AR5007EG - 802.11 b/g
Storage: Hitachi - 160 GB [8 MB cache, SATA, 5400 RPM]
Optical drive: Mats hita - 2 MB cache, DVD +/- R/RW/RAM/ROM, dual layer support, CD R/RW/ROM
Card reader: Ricoh - 5-in-1: SD, MMC, MS, MS PRO, xD
Webcam: Acer Crystal Eye (Bison) - 0.3 Mpixels
Connectivity:
4 x USB 2.0,
Broadcom Bluetooth adapter,
CXT Fax/Modem - 56K, V.92,
DVI,
ExpressCard,
IEEE 1394 (FireWire),
VGA,
RJ-11 (modem),
RJ-45 (Ethernet),
CIR (Consumer Infrared),
S-video/TV-out (NTSC/PAL)
Battery: Lithium Ion, 6 cells; (initially) discharge time ~3 hours
let me know
please do leave feedback and ratings for your free answer today.
May 08, 2010 | Acer Aspire 5520-5908 Notebook
I recently purchased a new battery for my acer Aspire 3050 and was told that it wont work if my laptop was dual core.I'm not sure what that means, is my 3050 dual core
you are in luck the answer is no its not dual core
Acer Aspire™ 3050 (LX.AV10J.037) PC Notebook The Aspire single core™ 3050 from Acer® provides performance, flexibility and value in a compact system. Featuring an AMD Sempron™ processor, wired and wireless connectivity and a stunning 14.1” WXGA display, this notebook brings productivity and entertainment to a new level.Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Acer Aspire 3050-1733 Notebook
Acer 5100 / AMD Turion 64 MK36 clock speed at 797 Mhz.
http://gd.panam.acer.com/home/ download and install e-power management then you should have all the options to change speed and other. i have 2 of these 5100 notebooks-and try the other apps on the link i put for you. if i can help further reply. also see the driver section, you may need some of those as well! good luck and be well!
Aug 03, 2009 | Acer Aspire 5100 Notebook
Processor update..
The problem with Store bought PCs is that there is no way to tell how fast a proccessor you can safely put into one before it becomes overclocking, but in theory your exact motherboard should support an AMD Athlon X2 5800+ 1000 Mhz FSB. Now if your willing to take a risk, you could buy a 6400+ but be warned, the computer may not recognize it, or it may just underclock the proccessor, if the processor supports 800 Mhz FSB. I said the 1000 Mhz FSB because it can underclock to that speed, and also because they no longer offer 800 Mhz flavors at the sites i order from. Hope that helps.
May 01, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
Open Questions:
Acer Aspire 5050 Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
