Question about Hoover Washing Machines
Timer is working but wont engage agitator have purchased new timer but still same
  • thomasroutle Oct 02, 2010
    hi kelly tested pressure switch stops at correct level does not engage agitator but timer still ticks over could pressure switch still be cause of agertator not engaging
  • Hoover Master
  • 3,740 Answers
Agitation is started when the water level pressure switch senses that the water has reached the selected water lavel. The water level pressure switch will have a thin rubber tube attached to it. If you have an automotive vacuum line you can disconnect the existing hose with the TUB EMPTY attach the vacuum line and orally force air into the hose. It should click and start the agitation with the lid closed as you force air into the hose. If it does not click the switch is bad.
(Let me just mention that if it does NOT agitate or Spin the lid switch is the prime suspected failure).
If the clicks and still does does not agitate there can be a problem with either the motor switch / winding (reversing motor) or it can STILL be caused by a bad contact in the water level pressure switch.
If you need parts data I will need your model number to help you with that.
Thanks for choosing FixYa.
Kelly
Posted on Oct 02, 2010
  • Kelly
    Kelly Oct 02, 2010
    Hi again.
    If the pressure switch ticks over and the motor does not start there are only 2 things at this point that will stop it form agitating those are:
    1. Lid switch (but the washer would not spin also)
    2. A problem with the motor wiring / winding or motor switch
    Usually I would add the timer to the list but you have already changed that.
    The pressure switch is allowing the timer to advance and that is the same power that would start the motor.
    If you have a meter here are the tests of the motor windings:
    http://www.applianceaid.com/direct_drive...
    Use the link above as there is a figure with the motor terminals above this text:
    A) Check for continuity on the start windings between black and *yellow* wires. A resistance of 4 - 7 ohms is normal.
    B) Check for
    continuity on the high speed windings between blue and white wires. A resistance of 3/4 - 2 ohms is normal.
    C) Check for
    continuity on low speed windings between white and white/violet wires. A resistance of 1&1/2 - 3 ohms is normal.
    D) Check for
    continuity on the extra low speed windings between white and white/orange wires. A resistance of 1&1/2 - 3 ohms is normal.
    E) Check for
    continuity the motor safety protector between white and white/black wires. You should see full continuity with 0 ohms.
    F) If all these check points are OK...then you can test the motor centrifugal switch by first removing the pump and disconnecting the motor wire harness from the switch, and the switch from the motor. Remove the internal motor wires ( write down which color and what terminal they came from ) and check the switch contacts as said here....
    By pushing up on the switch actuator, you should have
    continuity between the red and black terminals, as well as the orange and blue terminals.
    By releasing the actuator, you should have continuity between the orange and the white/violet terminals. No continuity should be seen between the red and black terminals, or the orange and blue terminals.
    Kelly
  • Kelly
    Kelly Oct 02, 2010
    I have to ask.. is the motor running but the agitator not moving? Y? / N ?
    If this is the case there is an agitator drive piece under the agitator than can be bad or the agitator itself. If the motor is NOT running at all when it should be, try changing the selected wash speed several times and see if by chance it works on high but not low or vice versa.
    Speed switch position change... Motor runs Y? / N?
    I am trying here just need to make sure we are communicating well.
    Kelly
My washer does nothing when you put it in the rinse cycle however it does fill with water. I believe the problem is the timer switch. can you confirm this issue
Not so? If it does not go into agitation? You may have a bad water pressure switch which sends signal to start agitation. but also can have bad cam dogs in agitator which do not engage agitator? a bad door switch will not allow agitation or spin on some appliances. And lastly yes u may have a bad timer wheres points have fused? can check most of these with a multi meter
Feb 05, 2015 | Maytag Washing Machines
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Wont agitate
Does the motor operate? If so, remove the lower panel carefully and look to see if it threw off a drive belt. If you have the type where the motor bolts to the transmission assembly and it's shaft directly engages inside transmission, the fault is inside the tranmission.
If the motor does not operate in wash cycle, but spin works, it is likely the contacts in the timer wore out.
Dec 19, 2011 | GE WHSB8000B Top Load Washer
The washer will fill up for the wash cycle and agitate for a few minutes then stops it wont drain , refill or spin . we have already put a new timer on it
The lid switch is bad. Very common issue on this unit. I can explain how to make this repair and also provide a place you can purchase the part.
Apr 22, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore washer solenoid clicks and chatters on agitation
I think the magnet you are referring to is the "wigwag" It's a control magnet used to raise or lower the plungers, shifing the cam bars to either the agitate or spin position. One coil shifts the cam bar that engages and disengages the spin cycle, and the other coil shifts the transmission into and out of agtation and also shifts the lever on the pump for drain or no drain. If the wigwag is not functioning properly, it could be causing your problem. Anyway, hope this helped and best wishes.
Aug 30, 2009 | Washing Machines
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Wont agitate on its own
IT SOUNDS TO ME LIKE THE START CONTACT IN THE TIMER IS NOT MAKING A CONNECTION UNTIL YOU PULL OUT ON THE SHAFT OF THE TIMER. MOST TIMES IT NEEDS A NEW TIMER.
Jan 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine wont work on certain settings
the selector switch for loads is just a switch that connects parts of the timed cycle to the timer circuit. if the timer is not rotating then nothing will work. check the connections through the selector switch. burnt or melted contacts within the switch calls for a new switch. try repair clinic dot com for a replacement.
Apr 19, 2007 | Maytag Dependable Care LAT9706
Washing Machines Logo
35 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
