The screen will turn on for an instant and then go blank. If I tilt the monitor forward it stays on.
  • 139 Answers
If u r using a crt monitor then the problem will likely come from the horizontal line driver(transistor) the big transistor that is closed to the line in the monitor and is usually attached to a sink. what to do
loos yr monitor use yr meter to confirm the transistor is still ok if yes then check for some open circuits around the board and resolder them. open circuits could be broken lines week soldering n etc.
thank u
Posted on May 26, 2008
    Brigadier General:
  • 6,966 Answers
Based on your description it could be a loose connection. Externally, this could either be the power cord or the video cable, internally, this could be on any of the different connectors or less likely, a cold solder. Depending whether your monitor is the conventional CRT or an LCD, then it could be on the regulator board or the inverter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Hey i have a Toshiba Equium M40X-148 and the screen wont turn on. When i power the laptop up the power light lights up but the screen stays blank. Any ideas on what the problem maybe
If you tilt it to the light, do you see a faint image?
Can you connect the laptop to a external monitor and toggle the FN + F5 key to adjust monitor settings to output to the 2nd screen.
Feb 10, 2011 | Toshiba Computers & Internet
How do you tilt screen back
just get hold of the top and bottom of the monitor and push it back or forward.
If it wont tilt with minimum effort, it may not have a tilt function, or it is broken, i have never had any problems with any monitor
Aug 26, 2010 | LG 22" FLATRON LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Satellite 1115 blank screen at start up.
Try using an external monitor. If an external monitor works then the issue may be backlight if not then the issue is the LCD screen. the way to test that is after you have used an external monitor to verufy booting and the the system works. then if the machine is out of warranty you remove the bezel anf the screws holding the lcd in place. lean the lcd forward. with a flash light on turn your system on and flash the light through the display if you see your post and or windows with the flashlight then the baclight is bad. if not lcd is bad. If you can not get teh external monitor to work, then your motherboard is bad or graphics card.
Dec 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
Blank screen Compaq Presario 1200 notebook
you have changed the settings
do you see screen of bios?
if yes then u will have to run the machine in safe mode and change the resolution
Nov 07, 2008 | Compaq Presario 1200 Notebook
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
