The volume on all inputs except the tuner is quite low (much lower than the tuner). Set is Vizio VX37L, and is about three years old, and it seems it's always been this way. I use an accessory audio amp sometimes, but it would be more convenient if set itself had adequate volume. Mfr's support has no solution and doesn't seem familiar with the problem,
  • stevied777 Oct 03, 2010
    What you say makes sense, but in fact, the level is so low on all but antenna input, that the volume is usually set all the way up, and is barely adequate unless the the aux. amp is used. By the way, I have seen other references to this problem on the web, but no solutions provided.
    Yes, the amp is separate, with its own speakers, (and even that I have to drive fairly high, because the input level from the tv (the Vizio audio out) is low.
    And yes, I have many times tried the settings, reset them and readjusted, but the choices are limited to bass, treble, mono/stereo, and surround sound. I have noticed that some sets, including some Vizios have advanced audio menus, and I was hoping there was some secret to open that, but so far, no luck. I'm on the verge of taking the set apart (I'm an engineer, and the warranty is long expired anyway) butI really wish there were an easier solution.
  • 666 Answers
Well it sounds as if your power supply is going out on you however this is a little irregular I would suggest taking it into a technician and have them try running a diagnostic to find out which piece of hardware is causeing the issue what you can do first though is look through the manual for a factory defaults reset after doing this the tv should revert to its original setting and if for some reason it was software related this should solve the problem
hope this helps
Robb
Posted on Oct 03, 2010
    President:
  • 2,777 Answers
That is very strange indeed, it sounds more to me that the volume on the tuner is abnormally high and all other inputs are working properly. Many cable boxes and satellite boxes have built in amplifiers as well, and it could be just outputting the sound for that at a much higher level than the other inputs. Even if you are using coax and no cable box, the sound coming through a coax cable is generally at a higher level than regular component / rca / hdmi inputs.
Or is it so low on the other inputs you can barely hear it even when turned up? I would bet all the inputs are working correctly, just that the tuner is louder than the rest...
Tim
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    Hmmm, ok so with the auxiliary amp it is fine though? And that amp is separate from the TV, is an amp you owned? Interesting..
    Have you gone into the setup on this inputs and checked the volume / sound settings? I believe on these Vizio's they are independent for each input.
    THanks
    Tim
  • Tim Grayson
    There definitely is no back-end setup menu for this tv that includes volume control, I've verified... unless it's some "top-secret" one that only the engineers who built it are aware of. I really don't think there is any other way to crank up the volume on those inputs, that is very very strange indeed.
    Still researching to see what else you can do here..
    Tim
My vx37l powers on get a blue screen then shuts down
Displays blue screen and shut down; denotes no signal input to TV. Check all the signal inputs, Ariel, AV or so. If all are found OK, the tuner to this TV is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 22, 2014 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Comcast 3 in 1 Remote code for Vizio VX37L television
The codes are:
10864
10885
11756
11758
10178
11017
10030
11265
10178
10700
10856
11178 - this one worked for mine
11993
Dec 30, 2008 | Vizio VX37L Television
Changing from 480i to 720p on VIzio VX37 with factory issued remote
If you use the hdmi input from your cable box and select either the HDMI1 or HDMI2 input setting it should automatically change based on the channel transmission resolution.
All this is currently controlled by the cable providers set top boxes, and depends on whether you have purchse the Hi-Def programming packages.
Hope this helps you.
Nov 03, 2008 | Vizio VX37L Television
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Vizio L37 37 in. HDTV LCD TV
I had a similar problem with my Vizio Model VX37L HDTV and replaced the main board myself for $160.00 which I purchased new on Ebay at ShopJimmy.com. The symptoms all of sudden started by the screen going blank except for a rectangular banner across the top that resembled a UPC code only garbled. No sound. I actually had to pull the power cord to turn off the TV. I was able to turn on the set normally but the TV menus did not come up. Since the TV was 19 months old and no extended warranty I checked with Vizio support and Sam's Club but no extended warranty=no luck. I did have an estimate for repair for $900 from a company Vizio recommended but a new one goes for less now. About 42 screws and a half a dozen pin connectors I replaced the main board. The set is working again better than ever. I don't know if I call my self fortunate or not since I did have a problem after only 19 months.
Jul 11, 2008 | Vizio L37 Television
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
