Question about Amana SXD524VW Side by Side Refrigerator
Fan runs all the time bottom part of freezer is ok top part of freezer not ok fridge side not ok what may be the problem ? I am an electrician but I cant troubleshoot because part of wiring shematics is gone.
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
I have a side by side Kenmore that is in our basement. Does not get too cold by any means, maybe 65 degrees year round ambient tempearture in teh storage room it sits in. 2 months ago we put a quarter of...
yes it sounds like your only problem is that the evaporator fan is not operating so open the freezer door and see if you hear it. if you do not hear a fan running in the freezer make sure that the other fan in the back and the compressor is running. just replace the evaporator fan in the freezer and that should do it
Apr 01, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active Smart® E522BR...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
My side by side fridge, fridge side is feezing up...
HI,GOOD JOB CLEANING THE COILS IT HELPS ALOT,MOST TIMES IF YOUR FREEZER SIDE IS FREEZING UP THERE ARE 5 THINGS TO CHECK,WHAT MAKE,MOST GE HEARTERS GO BAD FIRST,EASTEST TO CHECK FIRST IS THE FAN,OPEN FREEZER DOOR,IS THE FAN RUNNING,SOME MODELS YOU WILL HAVE TO HOLD THE FREEZER BUTTON DOWN FIRST,MOST ON INSIDE TOP,NEXT REMOVE FREEZER BACK PANEL WALL,IF YOU SEE A SHEET OF ICE,YOUR DEFROST HEATER(ON BOTTOM OR SIDE) AND THE HEATER TERMANATOR(LITTLE ROUND CLIP ON BALL WILL HAVE TO BE CHECKED WITH A OMES METER,YOU CAN DEFROST IT WITH A HAIR DRYER,WHEN DEFROSTED YOU CAN SEE IF THE DRAIN(MIDDLE BOTTOM OF FREEZER IS CLOGGED,LAST DEFROST TIMER(TOP FRONT,BACK BOTTOM,INSIDE FRIG.TURN CLOCKWISE SLOW TILL YOU HEAR A CLICK,SEE IF FREEZER FAN WENT OFF,WAIT 25 MINUTES,SEE IF FAN COMES BACK ON IF SO IT'S NOT THE TIMER,LET ME KNOW WHAT YOU FIND AND I WILL HELP YOU FARTHER-MIKE
Jun 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
GE Refrigerator Model GSS20IEDPD
check the back panel inside the freezer section near the lower shelf (not the bottom bim) for frost
Oct 14, 2007 | Refrigerators
Amana SXD524VW Side by Side Refrigerator Logo
66 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
