Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV simply would not turn on one day and all I see is the "lamp" light indicator blinking green very fast. Lamp is less than 1 year old. I have unplugged and plugged back in...nothing
  • 1 more comment
  • david_loe839 Oct 02, 2010
    The light after looking at it more closely is from the "timer" light and not the "lamp". I pressed both menu and device for 5 seconds and go no response
    hate to ask, but i have no idea what that is or how do check them...am i entering into the relm of having to call out a repair man
    so botton line is that the "timer" blinking light is a result of the DM Board or the Capacitors on the Power Supply and/or FMT Board
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Press the front panel "DEVICE/input " and "MENU" buttons at the same time, and hold for 5 seconds, please post back with the error code if you get any. If still it blinks continuously then please click on this link to resolve the issue. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 02, 2010
  • 1 more comment
  • Rylee Smith
    Rylee Smith Oct 02, 2010
    The issue seems to be with the DM board, also check the capacitors on the power supply and FMT board.
  • Rylee Smith
    Its always recommended to contact a professional if you dont have expertise.
  • Rylee Smith
    Yes right nothing else
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My tv won't turn on. the power supply is good but the lamp light keeps blinking. Does this mean i need a new lamp
Yes,if the tv LED light indication the word "LAMP" on the tv bazel frame is lighting up or blinking.The tv old projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and used daily 4 or 5 everydays?Yes,than ur tv projection lamp life are ended.Yes,than ur tv need a new projection lamp.
Apr 26, 2011 | Samsung HL61A650 TV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
Tv wont turn on Red standby/temp light and green lamp light are both blinking
The tv projection lamp been inside the tv like 1 1/2 or 2 years already,used tv every day like 4 or 5 hours a daily?The Lamp life are ended.Time to replaced the tv projection Lamp.
Dec 20, 2010 | Samsung HL50A650 50 in. TV
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
