Question about Whirlpool Washing Machines
Washer won't fill with water, spins and agitates, nothing else
    Problem Solver:
  • 12 Answers
Try replacing the water pumps at the back of the machine, that can be an easy fix just replace them sometimes it is the proplem
Posted on Oct 01, 2010
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer won't fill
Hi pollystepp.
Without knowing the make and model, a basic answer to this problem is that the fill switch has gone bad. If your machine proceeds to agitate and spin without water, the washing machine 'thinks' it has water in it and this happens when the fill switch is stuck open. Rarely, the tube that goes from the tub to the switch may be clogged which may cause the switch to remain open.
Good luck from Detroit, MI.
Oct 20, 2011 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
