My product is a Holmes oil-filled heater. The model # is HOH2505. There are two round control knobs and both are broken. Can I get a replacement? Frankie Moore
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. I don't have the answer to your knob problem other than to contact a Holmes Service Center. However, this particular heater was the subject of a recall (see link below.) Maybe you can get lucky and get a whole new heater vs the knobs should you have a unit with a product code listed at the bottom of this post..
http://www.holmesoilfilledheaterrecall.com
If you are in possession of a recalled model with a listed Production Code, contact us at (800) 306-2471 to confirm your eligibility and register for a replacement heater.
There is a 4 digit production code between 2 horizontal lines about 1/3 of the way down the product label.
These are the codes elligible for replacement:
Acceptable Production Codes 2305 0106 2405 0206 2505 0306 2605 0406 2705 0506 2805 0606 2905 0706 3005 0806 3105 0906 3205 1006 3305 1106 3405 1206 3505 1306 3605 1406 3705 1506 3805 1606 3905 1706 4005 1806 4105 1906 4205 2006 4305 2106 4405 2206 4505 2306 4605 2406 4705 2506 4805 2606 4905 2706 5005 2806 5105 2906 5205 3006
3106
3206
3306
3406
3506
3606
3706
3806
3906
Thanks for choosing FixYa.
Kelly
Posted on Oct 01, 2010
Testimonial: "THis is very definitely better than getting a new knob. Mine did qualify. Thank you very much. Frankie Moore"
I have a Holmes accutemp model HOH2520 TG-U. The heater operates for about 10-15 minutes and then the digital readout starts fluttering and it stops heating. The next day it does the same thing. Nice...
Hello- These heaters have been recalled.The Holmes heater company will mail you a new free heater, if u mail them back your power cord. Please check the recall website. Julie :)
Mar 02, 2011 | Holmes Products HOH2501 Oil Filled...
Heater is not coming on
That makes sense, you were pulling well over over 20 amps. It doesn't make sense but it appears the heater failed. I would assume the heater has an electronic control that got zapped by the surge generated by the vacuum cleaner when the breaker tripped. If it is not an expensive heater just get a replacement. Unless you are experienced in repairing these things it is much safer just to replace it.
Good Luck,
Gilshultz
Dec 01, 2009 | Holmes Products HOH2501 Oil Filled...
Control panel blinking
my heater did the same, very frustrating. i have solved this problem.  i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
Dec 06, 2008 | Holmes Products HOH2520-U Heater
My oil-filled Holmes heater HOH2520U will not heat now. it was working for a while the shut its self off and now the control panel is constantly blinking unless it is set at the room temp. HELP PLEASE
I had the same problem. this is what i did. unplug the heater. removed the plastic panel to expose the control panel where the blinking light is.  Removed all the dust and cobweb build up, then using rubbing alcohol, wiped the white residue that was on the green circuit board. I did this 10 days ago and the heater has been working fine since then. chaz
Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Thanks,
Nov 22, 2008 | Holmes Products Holmes HFH5506-CN Heater...
Not heating
Sounds like either the thermostat or the element. If you hear a clicking when you rotate the thermostat you can assume that it is working. My advise is to replacethe heater. The element is sealed inside the oil chamber and the thermostat will cost almost as much as a new heater, sorry.
Dec 05, 2007 | Holmes Products POH2501 Oil Filled...
Heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Oct 16, 2006 | Holmes Products HOLMES COMPACT OIL FILLED...
Heating & Cooling Logo
204 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
