Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 2166 won't start...........new battery and it just clicks has run fine for years do I need a new starter could it be fuse
  • Anonymous Mar 26, 2014
    put a new battery in and the starter will not click in to start engine
  • Cub Cadet Master
  • 7,482 Answers
Sounds like your solinoid switch is bad, replace it
Posted on Oct 03, 2010
Cub cadet 2166 will not start
trace back electrical connections with a multimeter until you find bad connection and repair
Oct 06, 2015 | Cub Cadet Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
How do you change the battery out of a Cub Cadet 2166 mower?
disconnect the ground wire first then the pos one there should also be a few bolts that hold the battery down
Mar 29, 2012 | Garden
I have a Cub Cadet 2166 . When I try to start it, the starter drive throws up, but won't turn the engine. I took the starter off and when you turn the key to start, the drive throws up and turns slow...
Can you measure the voltage of the battery? If you are getting low voltage then the battery needs to be charged or replaced, if the voltage is good then you probably have a bad starter. It might be something you can see like shorted windings on the motor.
Jun 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet that wont start.
Easy check is your cable connections and condition. Next would be to remove the starter and test it. Then check the solenoid.
Apr 27, 2010 | Garden
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Starting problems with my cub cadet 2166 lawn mower? Battery is good, not turning over, sometimes it clicks? I can jump start but it is a pain. I have taken this to a dealer last year for this problem....
If it works when jump started, then I would suspect a bad battery or lose or corroded connection. check wires from battery to starter relay also known as solenoid to starter,if it is making a click,the ignition is most likely ok . safety start switch is ok ,I still suspect Battery..can you have it load tested or try a known good one?PS if above test OK, then starter or starter solenoid /relay.Hope this helped you fix it. please let us know if this helped.thank you.
Mar 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
943 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
