Question about Mitsubishi WS-65807 65" Rear Projection Television
Blinking light light blinks continously no pattern will not reset or turn on
  • Mitsubishi Master
  • 8,617 Answers
Is your model the WS65807? f so you will need to change the 1000uf capacitors on the DM. If you need more info you can get the full service manual for your set at the following link and they will provide free tech support when you purchase a manual and also provide free instructions with pictures on how to do the DM board repair. heres the link they email the manual after purchase.
http://servicemanuals.vstore.ca/
Posted on May 26, 2008
Hi, has any one got any idea how I reset the program cycle on my Bosch SGS6312GB/07 dishwasher, any advice would be appreciated. Regards
Hello, usually turning off the breaker for at least 1 minute or more will reset the board. If you are getting a set of lights blinking, that is an indication of a problem--normally, dishwashers will blink certain lights in a pattern(digital error code) and depending on which lights and how many blinks, you have to decipher the type of code from the service manual.
Aug 19, 2015 | Bosch Dishwashers
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
Feb 10, 2013 | Frigidaire FTF2140F Front Load Washer
Green light working continously
It might be you change your cartridge to that and you did not insert it properly so that they blink. Try to check the cartridge if it can insert properly then restart your printer and try to print it again. If they are blinking again just press the reset button or turned off your printer then turned it on again and try to print.
May 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Trinitron wega kv-36fv15 - blinking light continously
yes u need services on ur tv , it could be ur picture tube , if it is your picture tube is not economical to fix
May 28, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture when turned on
The tile pattern on the screen is caused by a defective FMT board part # 930B924002.
Sep 15, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
