Toshiba a305 s6834 error 10-fa11-045d when I run the recovery cd at the end in the screen come out this error
SOURCE: toshiba satellite A205-S5847
well i had the same error on my toshiba...i spent literally 56 sleppless hours on the problem after giving up on the last 48 hour stint about 3 weeks ago...i installed a freash copy of xp...then used gparted live cd (linux small distro for partitioning hdds)to make a 10 gig partition in ntfs format....then i searched tiny vista and downloaded the torrent....that error is another way of saying you have messed up your bootmgr for vista..and it could have been a ton of things that did ruined it but none the less...after the torrent was downloaded (i know its not a legal copy but i used it just to fix my bootmgr) it has something to do with the way it sets up vista premium on your hard drive that fixes the boot problem.....and befor anyone says theres other ways to do it.....this is for extreme cases were you cannot afford a new hard drive and cannot get your factory install cd's to fix the problem ..... this is worth a shot in any case. .....forgot to mention that i used my windows xp partition to firstly download dvd decrypter and a copy of tiny vista (for you that dont know tiny vista fits on a 700mb cd and is remastered to install on its own with no help from you what so ever...then when i suggest deleting it from your hard drive and installing your own vista copy because after all all you needed to do was fix the boot... again..this is the only thing that worked for me other than buying a new hard drive i tried 30 different things and i garuntee i have heard it all..it was by accident that i found out this would fix the problem with oem instalations
Posted on Jun 23, 2008
frcs68
  • 1605 Answers
SOURCE: error code 10-FC06-000D while using recovery cd (backup)
Error code 10 XXXXXXX is related to hardware. It is default code generated by device manager when the operating system failed to determine which specific error code to return after an error occurs.
Error code 10 error pertains mainly to hardware issues and to compatibility issues between hardware and the software.
To troubleshoot the code 10, go to control panel>system> device manager and check if any of the hardware display a yellow “!” or a red “stop”.
1). Update the hardware device driver from either Microsoft or device vendor web site.
If the device is preinstalled on the computer, visit the computer manufacturer’s website.
2). Make sure the device is enabled in the computer BIOS. You need the system documentation, if you don’t know how to do it.
3). Disable any advanced feature of the device.
4). Install the most up to date service pack and any other updates.
Posted on Oct 29, 2008
shakeelm
  • 224 Answers
SOURCE: System Recovery Media error 10-FA11-045D
This error comes up if the toshiba recovery cannot recognise the file system and partitions. try removing all partitions using the fdisk utility or a windows XP CD and then run the recovery.
Posted on Mar 09, 2009
vlayne
  • 24 Answers
SOURCE: I use toshiba satellite A305-S6872 laptop would not load OS
you will most likely have to go into the recovery console to fix the problem or even re-install.
The other two solutions are to either boot up in safe mode to correct the problem by trying to revert back to a saved well working time, or take out pci cards and reboot always taking out another pci card until you find the problem.
if nothing works, re-install or fix in recovery console. <<< or >>>
BEST Solution
at re-install, choose repair windows.
Posted on Aug 24, 2009
KingDWS
  • 1606 Answers
SOURCE: my toshiba laptop (satellite A305-S6872) when
This can be caused by several things but you have to get past this point to actually figure it out. It is a software problem ie windows, a program or a virus or even an update that is the cause. If you just installed a program or update then this is what I'd look at first. You would also want to run an antivirus boot scan.
To get into windows you will have to get into SAFEMODE. When you first push the power button push and hold F8 down. It might complain but I found on Satellites if you don't hold it down it just seems to ignore the F8 key. This will pop up a menu and at the top will be the option of booting into SAFEMODE. This boots into windows but doesn't load any drivers or programs so the offending software isn't started or run. Your windows will look different but will look right when you reboot into normal windows. Once it is running you can uninstall any recently programs if you feel that is the problem or restore the system to a previous point where it was running properly.
System restore is found under start-programs-accessories-system tools
To untinstall any programs you think might be the cause use the add remove software found under control panel.
Once you have got rid of what might be causing this then simply reboot and your should now boot into normal windows. If it goes back to the blue screen then you didn't get the cause.You can try a earlier restore point or remove other programs or updates. If those don;t fix it then you have to consider using your Toshiba system disk to restore the computer back to what it was like when your first got it. This is drastic as it wipes out everything on your hard drive. If you can get into safe mode or safe mode with network you can use a memory stick to save off your documents, music, pictures, favourites, email addresses and anything else you need to. Your cd/dvd will not work in safe mode but the usb drives do.
While this is one of those annoying problems it isn't that serious but to fix it you need to be able to see a lot of information so all I can give you here is a few things to look for. At some point you will either fix it, or have restore it or take it to a shop but without seeing it I wouldn't be able to accurately tell you when that point is.
Posted on Sep 04, 2009
How to put in safe mode
Press F8 in the black start up section of your power up.
Jun 06, 2014 | Toshiba Satellite A305-S6834 Notebook
Touchpad is not working
check to make sure the touchpad shutoff button isnt on. its typically a button right above the mouse that has a light on it, or it can be a function key on the keyboard.
Nov 10, 2013 | Toshiba Satellite A305-S6834 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
Laptop will not scroll using my fingertip
Hi neilasmith1, I will guide you through the steps to fix the "Touch Scrolling." First, click on the "Start Button" paul7of9_43.jpg in the (right, pane) select to open the Control Panel: next open the [Hardware and Sound] category, paul7of9_44.jpg click on the "Mouse" applet. Next, in the Mouse Properties" (window) click on the "Device Setting" button, paul7of9_47.jpg once the window open, click on the "Settings" button just below the "highlighted" (Name) of the device: Synaptics TouchPad. paul7of9_48.jpg Try out some of the "items listed" Tapping, Virtual Scrolling... "You must click on the "Apply and OK buttons when finished. " Note: Restart the computer; this will make sure the changes are correctly applied, and working properly. "Rating the solution will let me know if the problem is fixed, or you will need further assistance, thanks for using FixYa, paul7of9"
Jan 13, 2011 | Toshiba Satellite A305-S6834 Notebook
Webcam,driver
It's better u go to Toshiba's website and find your model's webcam driver.
Nov 30, 2010 | Toshiba Satellite A305-S6834 Notebook
When we turn the laptop on, you can hear it turn on, but the screen remains black?
Propably the screen is damaged!
Connect an external screen to your laptop,
If the external screen is also black,
then its your graphics card adapter thats needs to be replaced!
Hope this was helpfull, Please vote!
May 14, 2010 | Toshiba Satellite A305-S6834 Notebook
No hdd recovery area!
have a look at this link and see if it helps you out. No hdd recovery area Google Search
Oct 13, 2017 | Toshiba Satellite A305-S6908 Laptop
Toshiba A305-S6834, video controler (VGA compatible) not installed appered when I installed, in a new hard drive, Window XP I need where I can find those drivers.
Your VGA card is a GMA X3100, in the GM965 chipset. You can go to http://www.intel.com/support/chipsets/sb/CS-025753.htm to download the drivers and software utility.
Mar 27, 2010 | Toshiba Satellite A305-S6834 Notebook
How to find and turn on scroll lock for toshiba satellite A305
To turn on Scroll lock you will need to press and hold the FUNCTION Key (FN), this is located beteween the Left CTRL key and the Windows key.
With FN Held you then need to press the F12 key on the keyboard, this will enable scroll lock.
just repeat the process to turn it off
quick keys:
FN + F11 = Num Lock
FN + F12 = Scroll Lock
Oct 17, 2009 | Toshiba Satellite A305-S6834 Notebook
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
