Question about Polaroid FLM-3232 Television
From power on, until about 20 minutes warm up, there is a high pitched squeal from the speakers, and random vertical color bars (can't see any video). After about 20 minutes, everything works fine.
  • Polaroid Master
  • 1,212 Answers
There are several weak capacitors in your signal board. You may need to replace as many as 15 or 20 capacitors. You will need purchase a cap checker. Many cases say to replace the signal board. But with great caution and patience a TV tech can do this for you! The power supply board will need one or two capacitors checked and replaced. As for the signal board, yes this is where the problem lies.
Posted on Oct 02, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
High pitched squeal from powerd speakers
Check to make sure the WIDEST blade of the AC power plug is actually the GROUND (as in "not HOT") in the new location!
Apr 30, 2017 | Peavey Audio Players & Recorders
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
Philips HTS3450 - high pitched humming noise until warmed up
Jeremy,
Read one of my posts:
I used a hairdryer and blew hot air into the grill on the bottom of the subwoofer enclosure which reduced the delay time from ~1hr to 5 minutes. (The high pitched noise was still there for about 1-2 minutes)
Oct 16, 2009 | Philips HTS3450 System
High Pitch squeal everytime t.v. is turned on. 20min warm-up.
sounds like the switchmode power supply is varrying in frequency ..needs to be checked by qualified tech,,,
Apr 16, 2009 | SNK Magnavox 19MF338B/27 19 in. LCD TV
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
Celestion S8
Most likely there are electrolytic capacitors in the power supply and also possibly in the amp sections that are going high in ESR.
It would be best to test all the caps with an ESR meter and then replace the ones that are out of spec. You have an excellent chance that this will fix the unit.
If you are not experienced at doing electronics servicing, you can give the unit out to a service center to have it fixed.
Jerry G.
Apr 06, 2008 | JBL PB12 Subwoofer
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Polaroid FLM-3232 Television Logo
69 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
