Question about Car Audio & Video
I have a new cd player was working fine then to day it just quit working the wires are fine and so are the fuses im stumped and dont know what to do
  • 400 Answers
Have you checked the fuse on the back of the stereo itself????
Posted on Oct 01, 2010
I just bought an 02 GMC Savana 3500 with 350 and I was told about 120k. Bought it cheap as heck as a known project but Im kinda stumped with electrical issues.
one point I am thinking is , the mileage for the car is too low so maybe a new dash was fitted and all the plugs at the back were not correctly fitted or ground wires were not connected
an 2002 is 15 years old
average distance covered is 20 k per year so the speedo should have over 250-300 k on it
Mar 12, 2017 | GMC Cars & Trucks
2007 camry radio
hey, that sounds like wiring for sure, if your cd player is working fine and its just your speakers? then yes that would be a wiring problem, theres a bad wire somewhere in the system. either find out yourself where the bad wire is or bring it to someone who know how to repair those types of problems. good luck!
Feb 15, 2014 | Cars & Trucks
Which fuse is the cd player in the fuse box
One circuit is constant power to keep the clock and station pre-set memory maintained. The other is for the radio in general. If the clock works, pull both radio fuses and put them back in one at a time to see which one is constant power. If one of them is blown, you can usually see the wire inside it is burned with a gap. I don't believe there is a separate fuse for the CD player apart from the one for the radio. If the radio works but the CD player doesn't, I'm guessing it's an internal problem.
Jan 27, 2014 | 1994 Dodge Dakota Club Cab
Vw polo 6n cd player has power but does not light up or play music
what color is the wire..it may be a memory lead..yellow or orange..some even have a power wire to the antenna so it will raise when the power is turned on..also may check the switches inside the unit that work with the eject part of the system..
Dec 28, 2013 | Volkswagen Cars & Trucks
Got a 98 k1500 4wd changed the turn indicators on the pass side one was out and the other broke front of truck put the wrong bulbs at first and all lights flashed.. checked the number on the other side put...
There is a small fuse in the cab fuse block ,for the insterment panel that is verry easy to miss if you don,t look close ,it is hidden kind of at the top of the fuse block behind the wires,
Nov 29, 2012 | 1998 Chevrolet K1500
I have lost power to my sony cd player in my car
Take the cd player out and run the 12+V to + on 12+V battery.
Run the Ground/Black wire to negative on battery. See if the cd player will turn on. If it does, check your ground in the dash. This is just a good trouble-shooting method to make sure the cd player system board is not fried.
Feb 08, 2009 | Sony MDX-CA580 MiniDisc Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Truck radio problem
it sounds like your wires need to be reran you might have a bad wire or two if that doesnt work email me
Aug 21, 2008 | Kenwood KDC-MP4028 CD Player
Power problems deh425
a-ha, 425, this is an old unit,they all are stop working!!, have you check the yellow and red, both must have (12.6v-13.8v) and of course a good ground.
Sep 11, 2007 | Pioneer DEH-425 CD Changer
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
