Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
I have a KitchenAid KSCS25FKSS00 side-by-side refrigerator. Freezer suddenly began warming and noticed divider between freezer and fridge very hot. Removed back panel and noticed condensor fan was not running, but it would start up if I gave it a spin. It eventually stops again and the warming problem returns. Does this mean the condenser fan needs to be replaced? I figure that it must be the fan rather than a control board since it runs when I spin it. Your opinions are much appreciated.
  • KitchenAid Master
  • 43,501 Answers
Yes, you need to replace that fan...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
Testimonial: "Good additional insight. Fast response."
We moved our refrigerator and cleaned the coils and now the coils are extremely hot and so is the outside of the fridge on the freezer side and on the divider between the the fridge and freezer.
The can get pretty hot. However you should check to see if there is a moisture control switch on that unit. Change that to the other setting and see what that does.
Feb 01, 2014 | KitchenAid Superba Architect KSCS25INSS...
My Kenmore Elite side by side refrigerator was blowing very warm air out of the grate at the bottom and the temp on the display in the fridge is rising. I also noticed the on the surface of the divider...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Aug 11, 2011 | Kenmore Side by Side Refrigerator
The divider between the freezer and fridge is hot to the touch. What is wrong?
there is a problem with your cooling fan motor in the lower back of the fridge it is either blown or has jammed.
Jul 13, 2010 | KitchenAid Superba Architect KSCS25INSS...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Divider between freezer and fridge is hot to the touch
That is not a problem, it is designed to use "waste heat" from the cooling system to warm this area to prevent condensation from forming there without having to use the extra energy required if an electric heater were used. It will be noticeably warmer while the compressor is running and has been running for a time than if the compressor has been off for a period of time.
Mar 28, 2009 | Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Heat build-up
Had this same problem and turned out that the coils at back of fridge and below doors were covered in dog hair. After vacuuming, area is no longer warm.
Aug 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,231 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
