Question about Hamilton Beach 70200 3 Cups Food Processor
Need replacement nylon gear ( the one that screws onto the motor shaft).
    Problem Solver:
  • 9 Answers
What exactly is your question? You already seem to have diagnosed the problem... Handiest1 10-1-10
Posted on Oct 01, 2010
How do I change the Nylon Driveshaft on my Magimix 4200?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and support the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 26, 2014 | Magimix C.s.4200 xl chrome mat - Mixeur...
Kitchenaid kfpw760 blade stem is stuck
The motor shaft sleeve and spindle will need to be replaced, once this jamming has happened it becomes ongoing if you do not replace those inexpensive parts. You need to wrap some webbing tightly around the spindle attach the other end to something very solid (like a fence post) and then accelerate the motor part rapidly away from the post. Hold onto the motor very firmly or it will land on the ground.The webbing tightens instantly when it runs out of slack and the spindle will come off. Then you need to remove the motor shaft sleeve in a similar manner, I drill a hole in the end and use a shackle and chain attached to the post for that one. I use the leg of my workshop bench, most folks will not have a solid heavy bench like mine. If that sounds too hard just take it to your local K/A service agent, they will have done it many times.
May 26, 2012 | KitchenAid Food Processors
I need a replacement blade for a rival food slicer model#1101
I own a Rival Food Slicer, Model #1101/8. I need a new blade which is 6-1/2" diameter with nylon bracket plastic gear riveted to inner side of blade and the screw which holds the blade in place. Please tell me how to go about getting one and how much it will cost. Thank you.
Sep 18, 2010 | Food Processors
Im trying to put a belt on a hobart 84146
I'll do my best to recall all the steps, I haven't done it in a while. Read instructions fully before starting, as step three may not be necessary, although if performed you'll have much more room for your hands during the remainder of the process.
1. Lay machine on side/back (so that the knife shaft is standing vertically) to access the bottom.
2. Remove bottom cover panel.
3. Remove motor. Two nuts are easy to access, the other two are quite difficult to reach. This step might not be necessary if only changing a belt because you should be able to slip the old belt off and the new one on without completely removing the knife shaft. If the knife shaft must be removed for some reason, the motor must come out to give you room to fit a puller onto the knife shaft (in order to remove the lower knife shaft bearing and lift out the shaft).
4. Take note of the knife shaft pulley. Notice how close to the casting the pulley is. When re-assembling, you'll need to position the pulley at approximately the same location for the black belt to track properly). Loosen two set screws securing pulley onto knife shaft and slide pulley down (don't lose the key for the pulley when you slide the pully down).
5. On the "outside" of the machine, remove the plastic cover where the knife shaft enters the casting.
6. Now visible is a special locknut and special lockwasher (sorry, don't know their names). One of the tabs of the lockwasher is likely bent upward into one of the slots of the locknut. Use a hammer & punch to bend the tab out of the locknut's slot, allowing the nut to turn.
7. Using a hammer and punch, position the punch in one of the slots on the locknut and spin the nut counter-clockwise with sharp blows with the hammer & punch. Have an assistant hold the shaft to offer some resistance to the shaft spinning if you're having difficulty. This may also be easier with the motor and belts still in position, using the motor to partially hold the shaft from rotating while driving the locknut loose.
8. With the locknut removed, spin it back onto the shaft a few threads with the flat side of the nut towards the casting (upside down compared to it's original, installed position). Don't spin it all the way on, you need room to fit a prybar under the flat edge of the nut.
9. Using two prybars, one directly opposite the other, under the now upside-down locknut, pry up evenly on each side of the locknut, and the shaft usually pops out fairly easily.
10. Back on the bottom side of the machine, slip off the belts and replace with new belts and reassemble machine.
11. Be sure to turn the locknut back around to it's proper orientation and be sure to tighten it with a hammer and punch just as during disassembly (special wrenches exist for those nuts, I don't know their name) and bend one of the lockwasher tabs into one of the locknut slots (even if you need to turn the locknut backwards slightly from it's fully tight position).
When everything is reasembled, be sure the flat black belt tracks properly, that is, make sure it doesn't walk off the pulley as the motor runs (just spin the shaft by hand at first to observe if the belt tracks properly.
Good Luck!
May 15, 2010 | Hobart 84145 Food Processor
The drive shaft extending vertically from the motor base has developed a crack. This runs from the top of the shaft down to almost where the shaft enters the motor base. The effect is to make the...
I just called Cuisinart customer service. Depending on your model, it sould be under warranty. They sent me a new shaft sheath immediately with no expense.
Dec 09, 2009 | Cuisinart Little Pro Plus LPP 3 Cups Food...
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Stripped gear on our Waring Pro FS150 Food Slicer
SmallAppliance.com has the part you need. Waring is no help at all. They only sell the replacement blade! Go to this web site: http://www.smallappliance.com/product.asp?pid=5147&cur=USD&cam=waring_parts&sid=18956&mid=34&gid=18971&prdCls=P&PartsPaNu=1&shopBy=Brand
and get the part. Thankfully they carry the motor gear you need. I had nothing but frustration dealing with Waring trying to get this part. Finally a nice Waring tech told me about smallappliance.com. Good Luck!
Apr 23, 2009 | Waring Food Processors
How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Mar 11, 2009 | Cuisinart Food Processors
The spindle (middle thingie) is broken
I don't know about the little lip you're referring to, but the central spindle that comes up from the base of our KitchenAid 12 cups food processor KFP750WH0 splintered and broke while we were using it. We ordered a replacement motor sleeve shaft part number KA8211849 from the Gourmet Depot for $4.95 plus $3.50 s/h. Removing the broken plastic sleeve shaft was the difficulty; it isn't glued or screwed on but somehow it didn't want to be pulled, pried, or cut off. With the help of our neighbor fix-it man and all four of us working at it with screwdrivers, we got the old broken part up and off. Pushing the new one onto the metal motor shaft was easy, and it was fixed!
Jan 16, 2008 | KitchenAid KFP750 Food Processor
Part removal and replacement
The black plastic clutch has a left-handed brass threaded insert. Temporarily remove the motor to hold the shaft and remove the brass insert by rotating clockwise.
Dec 26, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Hamilton Beach 70200 3 Cups Food Processor Logo
87 people viewed this question
Top Hamilton Beach Food Processors Experts
Jim Thurston
Robert Plante
Oloyede Monsuru
Are you a Hamilton Beach Food Processor Expert? Answer questions, earn points and help others
