Enter key on laptop
My enter button on my laptop doesnt work and i have a password on my computer and i can't get into it because of the problem with my enter key can you help me please
  • Anonymous Mar 21, 2009
    are you ******* a ****** i said fix the key not some other option retartd
    Scholar:
  • 139 Answers
U can use an oncreen keyboard if ur running winxp. to do this, click on start,all programs,accessories,assecibility,onscreen keyboard or beter still use the tab key on yr laptop keyboard after typing yr password keep presing it untill the ok button or enter or next which ever one u want to activate when highlited, click the space bar key it should work as enter key.
guess this helps
thank u for using fixya
Posted on May 26, 2008
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
Bios password on toshiba
Some Toshiba laptops come with a system BIOS password, making anyone without the password unable to get past the BIOS screen at system startup. This is a strong security measure, as it renders a stolen computer useless unless the password is known. If you have a Toshiba laptop and want to change the BIOS password, you can quickly do it.
1. Power on the computer while holding down the "Esc" key. Enter your current password when prompted and press "Enter."
2. Press "F1" to enter the BIOS setup menu. Highlight "REGISTERED" with the arrow keys and press the space bar. Enter your password and press "Enter."
3. Restart the computer while holding "Esc" and hit "F1" again to enter the BIOS menu. Highlight "NOT REGISTERED" with the arrow keys and press the space bar. Enter your new password and press "Enter." Type the password again for verification and hit "Enter." Press "End" to save the changes, and "Y" to exit.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Toshiba Computers & Internet
I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
Factory reset without using a disk and ALT + F10 doesnt work
his MIGHT work:
1. Click "Start," "Turn Off Computer" and then "Restart", if it is on. If your computer is off, turn it on by pressing the power button above the keyboard.
2. Press the "F2" function key on your computer's keyboard to enter the BIOS utility.
3. Use the laptop's right arrow key to scroll to "Main." Confirm that the "D2D Recovery" is "Enabled." If the D2D option is "Disabled," scroll down to the option using the down arrow key. Press "Enter" to change the option to "Enabled."
4. Use the laptop's right arrow key to scroll to "Exit." The "Exit Saving Changes" option will be highlighted. Press "Enter" to save the settings and exit the BIOS utility. Your Acer Aspire will restart.
Reformatting the Acer Aspire
1. Press the "ALT" and "F10" keys together while your computer is restarting and the Acer logo is showing to enter the Acer Aspire's reformatting utility.
2. Follow the on-screen prompts. Your laptop's hard drive will reformat and the original applications will be reinstalled. Your computer will restart after the reformatting process is complete.
3. Enter your name and other personal information when prompted during the Windows operating system setup process.
Mar 22, 2011 | Acer Aspire One PC Notebook
When i start my toshiba Laptop it asks for a password. How can i remove it
You can remove the password by pressing F2 at the BIOS menu, the screen before it boots up, and select using the menu "no password".
Hope this helps
Dec 23, 2010 | Computers & Internet
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
The enter key of my laptop sudden stopping working?
I would try getting some compressed air. Sometimes called canned air.
1915830-4u4zdtshcqwq1u3gjz1kqwnk-5-0.jpg Blow inside the keyboard, under and around the enter button and see if it helps. Do not hold the can upside down or sideways while spraying! It shoots out as ice and can hurt things further!
Apr 02, 2009 | Acer Aspire 3680 Laptop
Keys doesnt work
ok..... firstly check to make sure the "NUM LOCK" is off!!! if no joy get a usb keyboard and restart the pc with keyboard plugged in, hopefully if the usb controllers are enabled in the bios you will be able use the usb keyboard and enter your password, use it until you resolve the issue
Nov 14, 2008 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
1,676 people viewed this question
David Payne
David Payne
