Question about Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive
HDT725050VLA80 not readable
My computer is running a sata drive. I want to install the other as an ata/ide.
The drive appears in the Device Manager but not in the My Computer window.
When I checked it out via Computer Management/Storage/Disc Management, it states the drive is "dynamic, unreadable"
Can you tell me what I have done wrong, or not done?
  • ravi Oct 18, 2008
    My drive also states the drive is "dynamic, unreadable"
2 Suggested Answers
  • 111 Answers
SOURCE: HDD not recognised
HI Your Hard Drive is previously formatted and have done different partition provided by your previous machine where you took this hard drive from. Use "The Partition Magic" Software, it will help you to fix and repartition your hard drive in the new format. I have this problem before and now my hard drive can connect with any computer. The key in this issue is any hard drive goes with the original machine has been formatted and do its own partition from manufacturer so if you take it out later for use with other machine, you will need a software to completely rearrange the new partition in universal format so other computers can recognize it. This manufacturer purpose to protect your data from hacking, stealing once you take it out from the original machine. That is why when you connect it to other machine, this hard drive will not be recognized. I has this partition magic software and can make you a copy so you don't have to buy it. Just read the instruction and you can fix it for both 2.5" and 3.5" HD. Please email me at and provide me your mailing address, I can send the copy software to you. Regards, pingping
Posted on Jun 15, 2007
What is the correct Integrated Peripherals setting for PATA/SATA with a IDE hard drive on Primary IDE channel as primary system drive, CD Burner on Secondary IDE channel and a SATA DVD Burner on a SATA...
Integrated Peripherals Menu
1) USB Controller -> Enabled
2) USB Device Legacy Support -> Keyboard + Mouse
3) Use the Down Arrow, and highlight ->
On-Chip IDE Configuration. Press the Enter key.
On-Chip ATA(s) Operate Mode - > Native
ATA Configuration -> P-ATA + S-ATA
S-ATA Keep Enabled -> Yes
P-ATA Keep Enabled -> Yes
P-ATA Channel Selection -> Both
CombinedModeOption -> P-ATA 1st Channel
S-ATA Ports Definition -> P0-3rd
Configure S-ATA as RAID -> NO
4) C.S.A Gigabit Ethernet -> Auto
5) Onboard 1394 Device -> Enabled
6) Onboard Promise IDE -> Disabled
7) AC97 Audio -> Enabled
8) Set Super I/O -> Leave Alone
However let's not cut hairs here.
MAIN thing you need to do F-I-R-S-T, is to write down the settings as they are, BEFORE making changes.
In case a mistake is made, you can go back into BIOS Setup - Integrated Peripherals, and change the settings back to the way they were originally.
This way you can at least use the IDE harddrive, and IDE optical drive, with no SATA optical drive.
Then steam under your collar, find someone who knows more, than Ol' Joe.
(Better to have you ********** at me, than leave you with a non-working computer)
Don't forget to Save Changes, or it will be like you have done nothing at all.
(Need the User Manual for that mobo? Post back in a Comment)
Jul 30, 2012 | MSI 865PE-NEO2-LS Motherboard
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
When my computer was started in monitor display MBUltra133 (tm) BIOS Version MBUltra133 BIOS is not installed because there are no drives attached. SiI 3112 Serial ATA Host Controller BIOS...
If you are looking at Device Manager, the computer must be working to some degree. Since there are no drives on the SATA controller, you're probably using an IDE drive and don't need the SATA controller anyway. Disable it in the BIOS. And get more memory.
Dec 11, 2008 | Computers & Internet
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Oct 28, 2008 | MSI P965 Platinum Motherboard
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
Sep 09, 2008 | Compaq Armada M700 Notebook
Install hard-drive
Sata drives don't have an option to be master/slave like IDE drives, b/c the Sata cable is per device. If the computer's not pulling up the sata drive, open device manager (right click  my computer, properties, hardware tab, device manager) and look for a yellow question mark. You'll have to install drivers for it more than likely.
May 16, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive Logo
90 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
