I get a black screen after logon....no start option, totally black.
  • 78 Answers
Press the CTRL+ALT+DEL button (at the same time) on your keyboard and press Task Manager. now click on File then click on New Task Run. type in Explorer.exe and press enter. it should bring up your desktop wallpaper, Start buttons and desktop icons.
Posted on Oct 02, 2010
My laptop screen is blue with horizantal lines. After I installed a graphics card driver everything went fine, but the next day the laptop's display started acting weird. So I turned off the laptop and...
The OS-loading screen is a stong indicator that thee is nothing wrog with your hardware, but it is a driver issue. You need to press F8 as your computer starts up and enter SAFE-MODE.
Windows 7
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
    Figure 11. Windows 7 Advanced Boot Options screen
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
In safe-mode remove & delete the drivers you installed. If you can, revert to your old driver set.
Jan 06, 2011 | Computers & Internet
Aftr i start n log onto my pc... I can see d mouse but d entire screen is blank!!! Pls say what to do
We wish you a merry Christmas and a Happy New Year.
Which is the operating system?
What exactly happens when you start the PC?
Is it Blinking cursor with a black screen?
Then its black screen error.
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try this for free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below:
1) Restart your PC
2) Logon and wait for the black screen to appear
3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this)
4) Press the CTRL, ALT and DEL keys simultaneously
5) When prompted, Click Start Task Manager
6) In Task Manager Click on the Application Tab
7) Next Click New Task
8) Now enter the command:
"C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com
/download.asp?GRAB=BLACKSCREENFIX"
Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download process
10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be gone.
Hope this helps.
Cheers!!
Dec 31, 2010 | HP Pavilion dv6000z Notebook
I'm trying to change the screen resolution while running windows 7 because I have no desktop showing on my monitor
If you have these symptoms you can safely try our free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below: 1) Restart your PC 2) Logon and wait for the black screen to appear 3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this) 4) Press the CTRL, ALT and DEL keys simultaneously 5) When prompted, Click Start Task Manager 6) In Task Manager Click on the Application Tab 7) Next Click New Task 8) Now enter the command: "C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX" Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it. 9) Click OK and your browser should start up and begin the download process 10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue. 11) Now restart your PC and the black screen problem will hopefully be gone.
Oct 11, 2010 | Computers & Internet
Black screen just before login
Just boot your vista setup dvd and select repair option from the setup menu .... your problem will be solved... dont have to worry its just corrupt in your logon files its easy to recover.
Jul 19, 2010 | Microsoft Windows Vista Home Premium with...
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
Computer loading up but not logging on..
This has happened because of a Microsoft update:
In Safe mode (F8 at boot up)
Start-search for cmd
With search result -cmd- right click choose option Run as Administrator
type in- net user administrator/ active:yes
type- exit
restart- pc logon screen should show administrator account
if you can logon through this account, alter any accounts you want through control panel
Apr 21, 2009 | HP Pavilion dv6000z Notebook
Black screen after WinXP boot, same in Safe Mode
Pressing F8 during startup, just after the BIOS screen, will give you the
safe mode menu, including the option to create a '%windir%/ntbtlog.txt'
bootlog file
or you can try to restore xp:
Description of the Windows XP Recovery Console:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;314058
Mar 15, 2009 | Dell Inspiron™ 600M PC Notebook
Acer t180
Did you install some program lately?
If yes,
1.- Start up your computer and before windows start hit F8
2.- You will see a black screen with many options
3.- Select "Safe Mode"
4.- After Windows loaded up, uninstall the last programs.
5.- Restart in normal mode
Sep 25, 2008 | Acer Aspire™ T180 PC Desktop
I have windows Xp running on my desktop. Had no issues starting it up and working on it until a couple of days ago when suddenly it won't let me get past the initial logon screen, where it prompts me for a...
At the logon screen, click advanced options, you might have three options here.
User name
password
and a third one, Is there a dropdown option here, if so see is there an option to "log on to this PC"
have a look and let me know
Aug 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
