Question about Kenmore 43142 Front Load Washer
There is mold on the rubber seal of the front loader washer. If I fold it back to see the drainage holes, there is mold there too. I wipe out the front now, but the washer usually smells even tho I leave the door open between loads.
    Problem Solver:
  • 9 Answers
First, wipe down the affected areas with a bleach solution and hot water. Then run a long, hot cycle with the maximum amount of bleach in the dispenser. You may also leave the door open between loads as you did before, but run a dehumidifier in the room too. Mold cannot grow without moisture.... Hope this helps! Handiest1 10-1-10.
Posted on Oct 01, 2010
How to clean the mold of the rubber
If you have mold on the rubber gasket of your Duet front loader, I can almost assure you that you have lots of mold in other places in the machine. Front loading washing machine are almost hermetically sealed and if the door is left closed, the inside just never dries out. This is just a perfect environment for the growth of mold and other fungi. Once mold gets established in materials such as rubber gaskets, it can be very difficult if not impossible to eradicate because mold grows "roots" deep into the pores of the material, making it very difficult to remove. Eradicating the mold may result in damage to the gasket since my "cure" is to paint on full strength bleach on the moldy surfaces with a brush or sponge (wear gloves). Repeat if necessary. You may wind up having to replace the front door gasket to get all of it. It will probably take more than one application to fully eradicate the mold from the VISIBLE surfaces of the rubber gasket. If you remove the detergent dispenser and peer inside the opening, you may see a lot more mold inside the cavity. If you see mold inside the detergent dispenser cavity, imagine what the rest of the inside of your machine must look like. Do you run a periodic cleaning cycle as advised in the operating manual? Have you read the operating manual? Do you use the absolute minimum amount of HE (non foaming) detergent? Factory instructions for cleaning the door gasket call for mixing 3/4 cup of bleach into 1 gallon of warm water and applying this mixture to the affected gasket area, let stand 5 minutes and wipe the area down with a dry cloth. My experience has shown that this is a grossly inadequate concentration to deal with a deeply seated mold problem in the door gasket. To run the cleaning cycle, the factory calls for 2/3 cup of bleach to be added to the bleach dispenser. "Use of more than 2/3 cup of bleach will cause product damage OVER TIME". Initially, I would definitely consider using a whole lot more bleach than recommended and run two or more consecutive cleaning cycles. Then EVERY USE OF THE MACHINE: wipe the door gasket and all the creases and folds dry with a sponge, remove the detergent dispenser and wipe the cavity dry, leave the drawer out to dry on a clean towel, leave the door open, buy a cheapy plastic box fan and place it inside the machine and let it blow air around the inside of the machine for an hour or so to dry it off quickly, run a cleaning cycle at least once a month. If this sounds too involved or difficult, I would suggest switching to a top loading washer that is much less prone to develop mold growth as air can circulate in these types of machines to a much greater extent than the front loaders.
Sep 12, 2014 | Whirlpool duet Washing Machines
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    I heard you are suppose to clean the washer once a month to prevent mold,is that true?
    I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
    Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
    Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
    Sep 28, 2009 | LG WM1814CW Front Load Washer
    Allways smells like mildew when open up
    Yup, my front loader has the same issue. I found the rubber seal around the door has a fold in it that holds water and sometime candy wrappers and various stuff from pockets.
    By wiping the fold in the seal out on occassion and not closing the door in between uses, the issue was resolved.
    Jul 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Mold in rubber ring front loader Fridgidare washer
    Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
    Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
    How do you replace the door seal on a Bosch Nexxt front load washer?
    Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
    Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
    Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
    Refit the seal round the front of the cabinet,and refit clamp at front.
    Plz rate this solution.
    Thanks.
    Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
    Affinity Front loader
    Its normal for water to collect in the seal folds. The main thing is to dry it out completely. Take a dry cloth or sponge and try to remove excess water. Leave the door open to dry it out. You can even use a de-mould agent spray (many varieties available in the market). The main idea is to kepp the folds dry.
    Hope that helps!
    Sep 28, 2008 | Frigidaire ATF6000ES Front Load Washer
    Door seal wont drain
    I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
    Aug 23, 2008 | LG WM2487H Front Load Washer
    GE WASHING MACHINE GE PROFILE
    There is a product out there called Affresh. It is a tablet that can be used on all front loaders that do not have a Clean Cycle. It works great. It comes three tables to a bag. You should use all three the first time that you do this. After that, once a month is all that is needed. Two suggestions to help eliminate the smell and mildew. One, keep a wash rag handy and wipe up any water that remains in the door seal. Second, leave the door open for a day so that the washer can air out. This applies to all front loaders, not just GE, that do not have a Clean Cycle. Also, water sometimes stays in between the inner and outer tub. This water can become stagnant and create mildew, mold, and odor problems. I hope this helps!!! -The Appliance Braniac
    Apr 07, 2008 | GE Energy Star WCVH6260F Front Load Washer
    Kenmore 43142 Front Load Washer Logo
    288 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
