Question about Maytag MZD2766GES Side by Side Refrigerator
We cant get the fridge to make ice cubes - Maytag MZD2766GES Side by Side Refrigerator
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Oct 02, 2010
I was told that my new refridgerator will come with an automatic ice maker. What does that mean?
These days, modern fridges come with automatic ice makers that are built into the fridge itself. The fridge automatically fills the ice holders with water that then freeze into cubes. You can then tip the ice onto a tray that is removable and then the fridge will automatically re-fill.
Feb 18, 2013 | Home
Why can't I select cubed ice on my ge monogram fridge, all of the other buttons work fine.
the reason for this problem is a jam of ice inside the ice bin that will not let the knives that crush the cubes,and cant release to let cubes go by uncrushed,remove the ice bin,put the remaining cubes in a bucket,or toss,then check the ice auger in the bin and if theres a build-up of ice melt it with hot water,then thoroughly dry it,then replace this unit into the freezer,but do not use it until its cold again from melting the ice jam,then resume the ice making cycle
Nov 24, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Ice maker is crushing ice when cubed ice button is on
The problem is in the selector switch itself. If it is a touch pad, you will have to reset the control board by unplugging the until for 3 min. if its a physical switch, it may be faulty and will need to be replaced.
Good luck. please rate my answer as a fixya!
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker not working
It is under warranty, please call for service before it runs out!
Jan 03, 2008 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
