Question about Sony PlayStation 2 (PS2) Console
PS2 Ribbon I pulled the ribbon out that connects the power and open tray . Is there a way to reconnect it. Or am I screwed?
  • Skullyking May 26, 2008
    I added a problem to the post, and i think i am having the same problem.
  • FR3SH Jun 23, 2008
    the ribbon is out on the same side as the console it not torn and i cant figure out where the ribbon is supposed to reconnect
    Champion:
  • 207 Answers
There is but you must open the system and take it ALL apart then reconnect it!
UNLESS you pulled it from the shell.. There is the led lights which are connected to the shell if you actually tore the ribbon then get a new ribbon and shell on ebay 10$ ish!
If not tear it all apart and re-insert the ribbon to the bottom unit which holds the laser. If you need pictures of what I am talking about let me know as it is a complicated process which took me a full hr when the system first came out!
Posted on May 28, 2008
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
Disk reading error
Hi Tyrell,
What kind of disc is it? The PS2 can sometimes have a dirty lens and not read discs. It does not matter if the Disc is new and unscratched.
  4. REmove the Warranty sticker to the right edge of the power socket.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  10. REmove the little white disc from the Cd tray lid.
  13. Put it back together, and your in business.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
PS2 Read Error
PS2 power ribbon
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 Wont Play
Oct 30, 2007 | Sony PlayStation 2 (PS2) Console
Playstation..2
Hi Sammy,
You have a connection problem in the Reset Eject circuit.
  7. Check to be sure the ribbon cable coming from the reset/eject cable is fully inserted in the second connector from the front.
If this is not the case, you may want to check out www.playstationclinic.com . This could be a circuit problem and may need technical knowledge to gain repair.
Ps2 eject ribbon
is this ps2 slim or original
Aug 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
