Question about AT&T Sony Ericsson W580i Cell Phone - White
W580i doee not trun on at all
My W580i went dead few days ago. I have checked the battery and I know it has enough juice. When I press the on/off button a red blinking light comes on for few seconds. Do you know what is wrong?
  • 9 more comments
  • Anonymous May 29, 2008
    my w580i is dead checked the battery but no problem,its totaly dead.
    pls advice.
  • Anonymous Jun 18, 2008
    same sort of thing happened to me but i am thinking to take it to the service center
  • Anonymous Jun 19, 2008
    will not turn on at all battery fully charged but phone will not work sent back to sony ericsson waiting to see wat they do
  • dev_madhesia Jul 16, 2008
    My W580i went dead . When I press the on/off button a red blinking light comes on for few seconds. Do you know what is wrong?
  • aubsloveie Sep 28, 2008
    my sony ericsson wont turn on and it has a red blinking light flashing when i want to turn it on.. when i plug it into the charager it still wont turn on also.
  • maranonmicha Oct 03, 2008
    not turn on
  • Anonymous Dec 26, 2008
    First day using the phone. The screen went black... then no sign of life at all not even a blinking red light.
  • madhurah9 Dec 31, 2008
  • Anonymous Jan 02, 2009
    I have the same problem with my phone. And this is the second time happening to it. Last time I just kept it charged continuously for a few days and it just turned on. But this time it isn't working. So I am not sure. Oh and by the way I have the Pink one.. but its the same phone..
  • nellyzwiifey Jan 03, 2009
    I was in the middle of a conversation and my phone just cut off. My battery was fully charged before it cut off, but i put it on the charger to see if it would come on. When i plugged it up, it didn't come on. The battery bar didn't even come on like it usually does. When i try turning my phone on, it just vibrates a little bit and that's it. My mom has the same phone so i put her battery in my phone. It didn't turn on, but when i put my battery in her phone, her phone turned on. Obviously it isn't my battery, but it's my phone. Can someone please help?!
  • Anonymous Jan 08, 2009
    same happens i have the sony ericcseon phone w580i
    from new berlin wi
    shikhar shrestha
    Problem Solver:
  • 8 Answers
Dude, your firmware is corrupted. The solution is download the sonyericsson update service. The link is http://www.sonyericsson.com/cws/download/1/110/61/1231338335/Update_Service_Setup-2.9.1.10.exe. Download the application and install it. After you install it open the application and agree to the terms and service. Then choose your phone model. Then when it asks to connect your phone just take out the battery and put it back again then plug the USB cable to the phone while pressing the C Button. Then the application will detect your phone and check the phone's software. If your phone's has the latest softwares just reinstall it. It will take about 15 minutes to finish the update. When it finishes unplug your phone from the computer then take out and reinsert the battery and switch your phone on.
Posted on Jun 05, 2009
My pink walkman has been through many adventures with me. Although my contract is up and my phone has its flaws, it still should work. I woke up this morning to find it plugged into the charger with the battery out of it, sitting right next to the phone. It probably got knocked off the bed for the millionth time in a row. But i tried to turn it on, and it vibrates once, like it normally does when it's supposed to turn on, but then it doesn't show anything. Just completly blank... no sound, no picture. nothing. whats wrong, and WHAT CAN I DO TO FIX IT. IM DEAD IF MY PARENTS FIND OUT,
Posted on Nov 26, 2009
    Scholar:
  • 75 Answers
Although this can be attributed to the battery it may also be a damaged/faulty EROM. This has happened on two Pink 580i belonging to my fiancee. Her phone blinked red, the PC wouldn't recognise it, however the following may help.
You need a copy of setool2lite_1.11 but be warned certain elements will most likely show up as a virus when you download it. I assure you it's just a false positive and the files are fine. When you use the tool ensure your internet connction is off and disable your antivirus program temporarily.
ensure you have Sony ericsson USB drivers installed before trying this procedure
The procedure to follow
  1. Start SeTool 2 lite
  2. Press Unlock\Repair Button, The first button.
  3. Reinsert Battery
  4. Connect phone to USB cable holding 2+5 and keep held down
  5. Wait, SeTool 2 lite will repair the EROM, it will flash it back.
  6. Job done
Posted on Aug 21, 2009
Solution #2 ok, i had this same problem. the at&t store basically told me the phone was trashed and to just get rid of it. but first, i tried a solution on this thread, which was posted on Jun 05, 2009 by "kboydarkside". basically, it was a link to update the phone's software. ultimately, i had to reinstall the software (wiped out data on the phone, but that's a small sacrifice) . . .. but it worked like a charm!! :)
Posted on Jul 31, 2009
Call the customer service and tell them your phone just shuts off by itself. It's a flaw in the phone. Mine has done it several times. I sent mine back and they sent me a new one.
Posted on May 23, 2009
    Sergeant:
  • 218 Answers
It have got a very huge damage it is showing that the battery is not enough charged to turn it on,get ur battery a 12volt shot be careful check its negative and positive if u dont get it take ur battery to a near by cellphone shop
Posted on May 28, 2008
Dead phone
I know this sometimes happens with these smart phones; one day they just up and quit.
You could try a fresh battery, and check your charging source.
Mine did something similar a couple days ago - I thought it was charging all night long, and in the morning when I went to turn it on... nothing. It ended up being my charging cable, it wasn't putting any juice to the phone.
Apr 01, 2014 | HTC EVO 4G Smartphone
Having issues keeping the battery charged. Replaced Battery a few months ago and car was running great. Then a few weeks ago I started to notice that if I let the car sit for more than 3 or 4 days I...
I think it's doubtful that your starter is draining the battery. Once your starter is engaged upon start up, it is done with its job, and it is not needed until the next start up. It does sound like your starter is going bad. If all of the electrical parts seem to come on when you trying to start it, it should have plenty enough juice to start it. One possible cheap solution is it could be the starter relay. The relay takes power from your battery and routes it through to your starter. If this isn't working, your starter isn't even getting any juice. I hope this is the problem. I have seen many starters replaced that should not have been because fo a bad starter relay. You would have to Google that info on a Monte Carlo. I could not tell you where it is on any Chevy.
Aug 09, 2013 | 1998 Chevrolet Monte Carlo
Electronic clicking...won't start...??..
Dead/low battery, system won't engage the starter because there isn't enough voltage
May 04, 2010 | 2003 Ducati 749
Battery
have you had the alternator tested? it may be pulling your battery down when it sits for a day or so
Jan 21, 2009 | 2001 Lincoln LS
W580i won't turn on or charge
take the phone back and have it replaced.
Sep 03, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Motorcycle wont start
Check the battery connections, especially if you hear a click just before it goes dead. I know that on my bike, when this happens, the screws that hold the battery cables in place have backed out and not getting a good contact. You would think that with a bad contact that it would stay dead when you turn the key off then back on, but oddly, everything comes back on normally until I hit the starter button. Check the cables.
Aug 05, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
Screen works in playback mode but turns off in camera mode as if batteries are going dead.
For some reason, Fuji does not emphasize that if your batteries get low, this is what happens. You just need recharged batteries or new batteries. Be careful with rechargables--before recharging them when this happens, you first have to drain them using the discharge mode of your camera. Then they will take a complete charge. (Good for some 300 charges or so, I believe.) But if you don't discharge them first, they will take less and less of a charge, and last shorter and shorter. If you use regular batteries, they might not last for 50 pics before running out of juice.
Oct 27, 2007 | Fuji FinePix E550 Digital Camera
AT&T Sony Ericsson W580i Cell Phone - White Logo
593 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
