Question about Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 memory full
Keep getting memory full messages so i cant usu at all
  • 1 more comment
  • Anonymous Jan 10, 2009
    my gps won't navigate or take anymore information
  • ivanka769 Jan 14, 2009
    keeps coming up with 'memory full' - where is this memory?
  • yyeh Apr 05, 2009
    I was trying to update the software, but when I download the software, an error message states that I have not enough memory.
  • 35 Answers
SOURCE: When you are charging the Garmin Nuvi 660 how do you know when its done charging?
No way to know except you disconnect and watch your 4 baterry bars.
It take almost 4 hours to be full charge.
Posted on Jan 21, 2008
  • 71 Answers
SOURCE: Garmin 660 says memory full
Reset the device.
Posted on Aug 29, 2008
SOURCE: says memory full and will not work
I have Nuvi 250. Suddenly it started to say "Memory full" and "Waypoint memory full". It shows maps but d't routing.
Connected to PC I see about 52 Mb free space.
So saved files from POI folder ( custom POI) and GPX folder (current) then disconnected Nuvi and OFF.
Next step- depressing LOWER RIGHT corner of screen get ON.
I got " Are you realy want to erase all user data?"- Yes
And now problem solved!!
Yuo must again make your settings and copy poi and gpx back.
Posted on Oct 04, 2008
SOURCE: Garmin Nuvi 660 lost Europe maps
Eventually managed to speak to a man at Garmin who confirmed that it was not loading any European maps because it didn't have enough spare memory to load them all. He said that he would email me instructions for freeing up sufficient memory, the email never arrived but I decided to delet all the voice languages that were no use to me and all the other language 'help' files and tried again - it worked.
At no point did I get a 'insufficiant memory' warning, which would have been very helpful, nor is there any guidance for how much memory will be required when embarking on the update. Take note Garmin...
Posted on Feb 28, 2009
  • 3 Answers
SOURCE: Memory Full - Garmin nuvi 200
Turn off the device, push and hold in right-down corner on the display, and turn on the device. Hold your finger on the display, until you see "Do you really want to erase all user data?" message. Then click "Yes"...
Hint:
All private data will be erased. The user POI's too. You can backup the file G:\Garmin\gpx\current.gpx before erasing procedure.
Posted on Jul 21, 2009
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
Nuvi 660 will not figure a route and states "the memory is full"
Haven't heard of this issue but there's a lot of surplus stuff in the memory that can be safely deleted. Try connecting to the computer so you can see the files on the nuvi. Remove a lot of unnecessary voices and text languages. If you need Turkish or whatever in the future it can always be reloaded via the free Garmin WebUpdater. If you don't have WebUpater download it anyway (from the Garmin web site) as it's an easy way to check your GPS has the latest software and bug fixes.
Nov 03, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin 660 will no longer plot a destination...
Have you loaded a lot of JPGs or MP3s on the internal memory? If so, you have reduced the amount of memory available to the 660's OS. Not sure if the 660 stores calculated routes directly to the internal flash memory, but it is very likely, since it keeps your route when you power it down.
To unload the internal memory, consider buying an SD card - they are cheap right now. As a matter of fact, I just ordered an 8GB SD card for my 660 from Amazon for $13. The 4GB and 2GB cards are available for about $7 and $3 respectively. Drrrrrt cheap!
You can access the internal memory of the 660 on your computer with the USB cable you got with the 660. The two folders to focus on are the JPEG and MP3 folders. Simply copy these folders' contents to the root directory of the SD card, and then go into each folder in the GPS memory and delete the MP3s and JPEGs you added - should work better. The 660 will recognize the files on the card if left in folders named identically to the folders in the internal memory.
If you didn't add any content to the internal memory, that is a different issue altogether, probably something to discuss with Garmin. Could be as simple as upgrading the firmware. Make sure you select the correct version though, or it could be a fancy brick! Go here for the nuvi 660:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=164&pID=31946
Good luck, and I hope this helped!
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
I keep getting memory full message and route waypoints full on nuvi 610/660
The Navigator memory card will come with the a countrie's maps. Maybe you need to take the memory card into the computer and download more maps. Also try to erase the nt middle east location and start over.
Artgirl
Jul 08, 2008 | Garmin Nuvi 610 GPS Receiver
Memory full on nuvi 660
Try downloading the latest version of the firmware. This can sometimes help.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Hint:
Mar 23, 2008 | Garmin Nuvi 660 GPS Receiver
Dec 10, 2007 | Garmin Nuvi 660 GPS Receiver
Memory full
Have you tried downloading the latest firmware? Sometimes this can help.
Oct 29, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
447 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
