Question about HP Pavilion a1610n (882780664463) PC Desktop
How to copy to cd - HP Pavilion a1610n (882780664463) PC Desktop
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
I have a cd I want to copy but it is copy write protected
A copy protected CD cannot get copied to an other.
Apr 16, 2012 | Audio Players & Recorders
Goes straight to burn and doesen't copy
Which Program? There is a difference between Burn and Copy.
Copy means you have a CD or DvD that already has something on it such as a music CD or a movie DvD and you want to copy it. The system normally reads the CD or DvD and copies the contents to disk then asks you to put in a blank CD or DvD to make the copy.
Burn means you have Data Files, Documents or Music that is already on the disk drive and you want to put it on a Cd or DvD. Normally you just put in a blank CD or DvD then either Drop and Drag, Browse or Copy and Paste the files you want on the CD or DvD.
Mar 30, 2012 | Computers & Internet
How do you copy a cd on my laptop?
If it's an audio cd you need to rip it - use
http://www.softpedia.com/get/Multimedia/Audio/Audio-CD-Rippers-Encoders/Express-Rip.shtml
Feb 02, 2010 | Toshiba Qosmio F45-AV412 Notebook
I don't know how to back up my files onto a cd. Can anybody help.
With Windows XP and a CD-recordable (CD–R) or CD–rewriteable (CD-RW) drive, you can copy data to a CD as easily as you used to copy to a floppy disk.
To copy files and folders to a CD
1.
Insert a blank, writable CD into the CD recorder.
2.
Open My Computer.
3.
Click the files or folders you want to copy to the CD. To select more than one file, hold down the CTRL key while you click the files you want. Then, under File and Folder Tasks, click Copy this file,Copy this folder, or Copy the selected items.
If the files are located in My Pictures, under Picture Tasks, click Copy to CD or Copy all items to CD, and then skip to step 5.
4.
In the Copy Items dialog box, click the CD recording drive, and then click Copy.
5.
In My Computer, double–click the CD recording drive. Windows displays a temporary area where the files are held before they are copied to the CD. Verify that the files and folders that you intend to copy to the CD appear under Files Ready to be Written to the CD.
6.
Under CD Writing Tasks, click Write these files to CD. Windows displays the CD Writing Wizard. Follow the instructions in the wizard.
Notes:
• Do not copy more files to the CD than it will hold. Standard CDs hold up to 650 megabytes (MB). High–capacity CDs hold up to 850 MB.
• Be sure that you have enough disk space on your hard disk to store the temporary files that are created during the CD writing process. For a standard CD, Windows reserves up to 700 MB of the available free space. For a high–capacity CD, Windows reserves up to 1 gigabyte (GB) of the available free space.
• After you copy files or folders to the CD, it is useful to view the CD to confirm that the files are copied. For more information, click Related Topics.
Jun 27, 2009 | Microsoft Windows XP Home Edition
I tried to make an exact copy of a CD via Sony Vaio but the copy is messed up. Certain cuts sound scratched. The original CD is clean and plays normally. Does my CD drive need fixing? It (software)...
What type of CD did you copy? Different CD types have different methods for copying them (Example: a music CD has multiple tracks to copy; better to rip them then reburn them onto a blank disk; a DVD disk has multiple data, video and audio files protected on the disk, a straight copy wont work). Based on your question, you tried copying a music CD. Use a program like Windows Media Player, RealPlayer, or iTunes to rip the disk, then copy the ripped tracks to a blank disk. All three of these programs are free, and there are tons of other free alternatives out there to do this.
Mar 11, 2009 | Sony VAIO PCV-V200G PC Desktop
Magellan Roadmate Manager CD#2
Hi, I just sold a unit on eBay and it did have CD#2 but not CD#1 - can I get a copy of CD#1 from you and I will get you a copy of CD#2?
Jun 05, 2008 | Magellan RoadMate 300 GPS Receiver
Prepares download copies but has problem at final stage of copying to disc
It might be because your cd is not good at the end that's why it fails at the final stage to copy the cd..try using the nero software and when it open use copy cd option and when it ask for burning select image recorder......so when it copies the cd you will get information whether cd will be get copy or not..,
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 26, 2008 | Computers & Internet
1.5.1powercd+burner crack code
Any CD can be simply copied. I use Nero Burning ROM. Using the program - select Copy CD and it will copy any CD (including the security devices). Nero costs money to keep (and obtain the Nero Burning ROM as opposed to Nero Essentials which is available on the Trial ware and will not copy a CD) so you may want to go to a site like this:
http://www.download.com/CD-DVD-Burners/3150-2646_4-0.html
And browse through the downloadable programs - Read the specs as not all of these will simply Copy a CD and not all are free.
Note: It is legal to make a "Backup Copy" of a CD that you own, but it is illegal to make multiple copies of that CD.
Apr 12, 2008 | Computers & Internet
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
HP Pavilion a1610n (882780664463) PC Desktop Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
