Doesn't spin during spin cycle if open lid and spin the basket until it clicks, then it will spin.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described, the issue is with the Lid switch going bad and needs to be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 01, 2010
Sometime the wash cycle stops when the spin cycle should start.
From what you're describing it sounds like the lid switch is faulty. Open & close the lid slowly & listen carefully for the click of the lid switch. If you do not hear the lid switch, you will need to replace the lid switch. Other testing will require accessing the controls & using a meter to make some more checks with. If the motor is not running & the lid switch checks good I suspect the timer. If the motor is running in the spin cycle but the basket is not spinning I suspect the drive block, basket drive, transmission or clutch.
Mar 04, 2011 | Maytag MAV7200 Top Load Washer
Tip
How to fix a Washing Machine if it doesn't Spin
If the washer seems to complete all of its cycles but doesn’t spin:
1) Be sure the load of clothes is not lopsided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid and reposition the clothes. This automatically resets an off-balance shut-off switch. Then, just close the lid and retry.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn’t click when you press and release it, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The belt may be loose, worn, or broken. If you’re fairly handy, tighten or replace the belt; otherwise call a repairperson.
4) There may be a problem with the controls; if this is the case, call an appliance repairperson.
on Sep 03, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Motor running, basket not spinning during rinse cycle
with this issue i would look the the notor coupler
its a small plastic clutch between the motor and transmiossion
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Basket does not spin during rince cycle
does it drain/this will tell you if you did the lid switch correct-mike
Jul 17, 2009 | Kenmore 22422 Top Load Washer
Possible lid switch stopping basket from spinning
Lid switch is safety mechanism that cuts off power to motor when lid is open. If it is broken or faulty you will not get power to motor during spin. Hope this helps!
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor comes on and water gos out but basket will not spin untill lid is opened then closed again . this is on all spin cycles .
HI, you will need to replace the lid pressure switch. it is faulty or the wires may be worn or lose.in most cases, it will be a faulty lid switch.
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
