Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Memory card error - memory card locked when I turn on my camera it has the above error on the screen. The memory card worked fine for a long time before this. I put a new card in and the same thing happens.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
memory card error -  memory card locked
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 23, 2010
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Keep getting card error was working fine took card out to download pics on to my computer and when i put card back in i keep getting card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. Another common cause is card corruption from the card never being formatted in the camera. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 29, 2011 | Fuji FinePix S2000hd Digital Camera
Camera screen says card locked and a new mwemory card says error...please help
Aug 27, 2011 | Canon PowerShot S2 IS Digital Camera
Sanyo VPC-T700 Memory Card Error. All of a sudden the camera is displaying "CARD ERROR" message. Camera works fine witout a card installed. Help me please
Hello Karen,
Please look for lock in memory card as in the above image. If the white latch is in downside position then slide it in up position. Also check that you are inserting the memory card in right position in the camera.
Jul 03, 2011 | Sanyo Xacti VPC-T700 Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
My camera wont read memory cards anymore. It was working just fine, then the next picture I tried taking it said "memory card error" and the memory card works in other cameras, and my camera turns on and I...
Hello
Kind regards
Andrea
Aug 29, 2010 | Canon PowerShot A610 Digital Camera
Memory card locked
Use the camera to try to format the card. If this doesn't work use a computer to format the card. efore the camera can use the card, format the card in the camera. If this doesn't work, gently slide the lock back and forth several times and try this again. If this doesn't work, see if your friend can format it in his camera. If he can, then try formating it in your camera. At some point it will either work or it is compromised (toast).
May 29, 2009 | SanDisk Ultra 4GB Secure Digital High...
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
241 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
