Question about Magic Chef MCBR170 Compact Refrigerator
On the temp control, is 1 coldest or is 7? - Magic Chef MCBR170 Compact Refrigerator
  • 316 Answers
7 is coldest setting
Posted on Oct 01, 2010
Not sure which way to turn knob to make it colder goes from 1 to 7
1 being the warmest 7 the coldest most run around 5 to 6
Feb 05, 2012 | Amana Refrigerators
How do I make refridgerator colder....dial is one through 7... is # 1 coldest or #7
1 is the warmest
7 is the coldest
one thing to check is the condenser coil in the bottom behind the grill below the door..remove that grill and clean all the dust from it
when setting the controls nothing happens quickly it takes up to 24 hours to achive the lower temp it was set at
GENE
Aug 27, 2011 | Amana Refrigerators
Hello. Couldn't find the manual to a Montgomery Ward Freezer that we have. I'm not sure if if the dial setting of 1 is the coldest or 7. I couldn't tell the difference when I set it to the...
1 is the warmest
7 is the coldest
one thing to check is the condenser coil in the rear behind the service panel..remove that panel and clean all the dust from it
GENE
Aug 26, 2011 | Refrigerators
I have a Kenmore bottom freezer fridge. Can't find the manual. Is 7 the coldest setting or 1? We keep the fridge in our garage and with the artic temps we are having we need to adjust it.
most refr's dont so well when the ambiant temps fall below 50 degrees. you should not need to adjust the controls must past the "midpoint" usually 4. but 7 is the coldest setting.
the best thing you can do is check what the actual temps are in your garage and if you can warm it up to above 50, then the unit should run properly again.
if the ambiant temps are too cold, the freezer wont be cold enough and the refr section will freeze things.
Jan 06, 2010 | Refrigerators
Purchased a 2004 upright freezer i dont know how to set temp
sir seven is the coldest setting. Good Luck
Jan 10, 2009 | Kenmore Freezers
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Magic Chef MCBR170 Compact Refrigerator Logo
3,078 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
