Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG 5811 dishwasher stopped, OE code came on, water will not drain & cycle stopped
    Problem Solver:
  • 12 Answers
Drain hose error. make sure the hose is not kinked
Posted on Dec 15, 2010
  • jimmy573 Mar 31, 2011
    what are the trouble shooting steps.
    1. check the ensure the drain hose is not kinked
    2. check...
    3. then check...
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
LG 1419LF My dishwasher stops during its cycle, it shows an error message: OE, there is 2 inches of water at the bottom of machine...Please help...
Hi
Daniel
Aug 04, 2011 | LG Dishwashers
LG WASHER STOPS BEFORE THE END OF THE CYCLE..OE IS THE ERROR MESSAGE ON THE SCEEN
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Feb 04, 2011 | Dishwashers
Our dishwasher keeps stopping its cycle and saying 'OE' It is LG - LD/141ST1
the 'OE' code means clogged or kinked drain line. You will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. Be sure the hose isn't kinked.
Sep 22, 2010 | LG Dishwashers
Lg oe
oe is a drain error not drain in 5min
The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Sep 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE and OE
Apr 12, 2009 | LG LDF8812 Stainless Steel Built-in...
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
229 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
