Looking for a manual for a MP1 441 Monitor heater. Can't figure out how to program. Help....
Soulvisitor
  • 1113 Answers
SOURCE: shuts off after slowe burning ,8888 flashes, and all burner lights fash. Monitor 441 oil heater.
There is specific instruction on web site for 8888 code flashing, as bbtoast has instructed.
From a distance we are unable to do the test procedure, you will need to do it, follow the instructions given on THIS PAGE. you also will need a multimeter to test for the 2.4volts and also a 10K ohm resistor to test.
Without testing as instructed here are your options
06c7dee.jpg plus failure of combustion motor.
Sorry no magic wand available, you will need to get your hands dirty, part identifiers and circuit diagrams are also on given site
I think you will find that Brian has already indicated this much and there is not anything more anybody could tell you.
Cheers.
Posted on Jan 20, 2008
SOURCE: operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Posted on Feb 08, 2008
Hi, whats the difference between a "Model 41" and a "Model "441" Monitor heater? Are the manuals interchangeable and its simply a generational thing?
Thanks
Paul
Posted on Nov 11, 2008
  • 674 Answers
SOURCE: looking for repair of monitor 441 kerosene heater
Did you get your Monitor repaired? I'm located just north of Winston Salem. You can email me at nitensheaterservice@earthlink.net
Posted on Nov 22, 2010
  • 674 Answers
SOURCE: mp1 monitor 441 ran out
Check the fuel filter and the fuel strainer. The strainer is located on the right side of the heater at the bottom. It is on the side of the fuel sump with 2 screws holding the cover on. Turn off the valve at the oil barrel before removing the strainer and have some rags ready to catch the fuel that will come out. You may also have an air bubble in the line. Use the small screw on top of the filter to vent the filter. You can also place a bowl under the line where it connects to the back of the heater and loosen the line so you can get the kerosene flow started. Hope this helps.
Posted on Dec 15, 2010
I do not know if I will get an answer, but here it gos, my moniter heater cuts on, starts to heat up a little and then makes a small click noise and then shuts off
Remove Obstructions The overheated condition may be caused by obstructions blocking the air flow to the heater. Check: • The front of the heater • The circulation fan (on the back of the heater). • The flue pipe (outside) Step 5: Remove the Louver Remove the screws at the louver, and carefully clean.
Below is a link to your manual
http://monitorproducts.com/wp-content/uploads/M441OwnersManual.pdf
Jan 14, 2016 | Heating & Cooling
My light won't ignite on my mpi 441 monitor
this morning my heater, monitor 411, was running fine as always.
while it was running the power company came to work on a pole and turned the power off. it was down for about three hours. once power was restored it wouldn't come on.
the pilot light is off but I'm not sure if it's suppose to be while not running.I've tried priming it with three pumps, resetting by unplugging, beleeding the line, all don't work.
it's suppose to be 22f tonight so I could sure use some help.
oh, I have a manual but, of course, it doesn't cover the problem. I also called the company but got a voice mailbox...go figure.
somebody please help!
Dec 20, 2012 | Heating & Cooling
Want a owners manual for Drayton Tempus Three Water heater
The Tempus three actually the controller not the heater itself. It varies from when the unit was made but I see the web littered with people trying to get this info. I trawled the net for a while to try and get a link for you but my best suggestion it to either email Drayton or you can find vartious instructions for the tempus 7, 2 and 1 that might help you figure out how to use yours. I'll keep looking and see if I can get a pdf. put on.
Aug 01, 2010 | Heating & Cooling
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Hayward 100 series Above Ground 100,000 BTU heater
This plate is an internal by-pass if it sticks open this is what you will get if it sticks closed the water will move to fast to heat and you will get low heat after it runs way to long. If it moves freely and has the proper spring in it you will get nether of these. For my money i would replace it with a new one and be careful with your chems as this is what will kill on and after time ruin the whole heater. Figure they pay a bunch of engeneers to get it right and virturaly all heaters have these in them in one form or another. In answer to your question you will want it stuck closed, but be reminded your heater will run on about twice the gas and get you mabey two thirds the heat.
Sep 03, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
How do i change the channel?
Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies. Figure 16.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Not heating /lg ldf 6810 st dishwasher
You definitely need to download the Service Manual. You can start the check program by pressing Upper Only+Time Delay+Power, but you need to know the sequence to be followed to check each component. I did this to fix my dishwasher (heater unit was deffective).
I recommend you to search the internet for the Service Manual (you can find it for download) and run the program.
Good luck !
Mar 04, 2009 | LG LDF6810 Built-in Dishwasher
Operating manual for MPI monitor heater
Jan 09, 2008 | Heating & Cooling
Sharp vcr
I wondered if you were able to get a copy of the manual. Does anybody know how to reset the tamper proof button that needs a code. MY child seems to have set this with a code.. Any help would be much appreciated. Thanks
Nov 05, 2006 | Sharp VC-H982U VHS VCR
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
