Question about KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher
My Kitchenaid KUDP02 dishwasher has standing water in the bottom and I cannot figure out how to clean the screen et al
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
  • 9 Answers
SOURCE: KitchenAid KUDP02 built-in dishwasher will not fill with water
Couple of things that come to mind here... May be helpful or not - but after all this is free ifo and probably worth what you are paying!!!
Anyway:
1: Have you tried removing power from the appliance?? All these modern appliances use a microprocessor and - like MS WINDOWS - need a kick up the bum now and then - (Well.. with Windows it seems to be every day- hour -minute - or so)
2: Dishwashers are installed with water reduction valves, so there could be a problem with one of there (particularly the hot water side).
3: The water inlet is controlled by soleniod valves (read: electronic valves). If the valves are not opening, no water will enter the appliance, so there could be a problem with the valves.
Posted on Jan 16, 2009
  • 17 Answers
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Posted on Feb 16, 2009
  • 423 Answers
SOURCE: How to unclog KUDp02 dishwasher
Are you still having problems with your dishwasher? Please post if you are.
To get to the chopper area and to the area you really need to get to, remove the lower spray arm and then one screw the holds down the filter/sump assembly. Look closely for debris and remove.
Check all spray arm whole for blockage.
Rememeber to only use a brand name DW detergent powder (like Electrosol or Cascade), not a generic, ultra-cheap powder or any gel/tablet. You will be amazed how much better it the brand name powder works!
Golld Luck. Please update me with what you find. OK?
Posted on Apr 10, 2009
I have standing water in bottom of GE GSD 666 dishwasher. I pressume I need to clean screen/filter? How?
I have the same problem, same model GSD660G0322. Have an inch or two of standing water. When I run the drain pump in Service mode, it successfully clears the water. How do I access the filter to clean?
Oct 22, 2011 | Dishwashers
Water standing at the bottom of dishwasher after cycle is complete.
The leading cause of that is a dirty/blocked pump filter ,that is restricting the water flow into the pump. This tip i wrote covers how to disassamble the pump and clean the filter. http://www.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Aug 31, 2011 | KitchenAid Dishwashers
I have standing water in my dishwasher. How do I unclog the drain?
It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
Aug 10, 2010 | Frigidaire Dishwashers
Poor washing quality and water left in the filters ets
My friend, that siemans is a night mare to open. Just done one recently. Anyway, looking at it simply, i would suggest you check the inlet water filter. if water is slow to come in it will cause this problem. Remoe the water pipe from the solonoid and look for sieve. clean it well retry.
Sep 21, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
Our Kemore dishwasher is leaking water onto floor, and the water valve continues to pour water when machine was turned off, but is not leaking water now. There is also standing water at bottom of tub from...
you just need to clean the pump area in the bottom of your unit :)
try to take spray arm out if you can and then open pump cover clean it good but watch for broken glass in it ...and thats it :)
Aug 12, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Upper two spray arms (Kitchenaid) are not rotating or spraying
I have had a similar problem. I found that I had to remove the spray arms and dislodge food waste that had gotten stuck in the nozzles. Whenever cleaning has been insufficient, this has always made things better. A shame that Kitcheaid didn't do a better job on their screens/grinder.
Mar 30, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Feb 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Anyway:
Nov 25, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Dishwasher not draining
look the draining pipe of it, check if there's something blocking it.
Nov 25, 2007 | KitchenAid Architect Series KSRP22FSSS 33"...
KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher Logo
100 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
