Question about Toshiba 42H81 42" Rear Projection Television
Tv on off swtch
Where can i get a power switch (on-off) for a 1997 toshiba tv and can i rplace it myself
    Scholar:
  • 131 Answers
Are you sure the switch is bad if it is physical probem easy to see. if it is not then you need a multi meter to ohm it out. You most likley will not find the original switch but maybe you can get a generic switch and you might have to modify it.here are place you can get switches
1 radio shack
2 www.mcmelectronics.com
3www.partstore.com
please be careful unplug first. if you can not solder dont do a tv shop will probably charge 45.00 to fix call and ask them on phone there costs
good luck Doctor video
Posted on May 26, 2008
TV does not swtch on
Provide some more info for your tv set and I might be able to help some more
Jul 08, 2014 | LG Televison & Video
I'm working on a 97 geo prizm and need to find the ignition relay,I rplaced the ignition switch and have no power getting to the switch,there is power at the harness and I can bypass the switch an
If you can jump it at the switch and get it to start, then the ignition relay must be working. It is hard to tell from your post but I think you are using power from another source to do this? I am thinking you have a blown fuse on the wire the furnishes power to you ignition switch.
Feb 12, 2012 | 1997 Geo Prizm
POWER DOOR LOCKS LOCK AND UNLOCK WHEN CAR IS ON
This can be caused by a couple of things, but the most common cause is a bad door lock swtch. It can be either side, but usually the problem is the switch on the driver's side.
Nov 14, 2011 | 1997 Mitsubishi Galant
How do you do a printer report on the 452 toshiba photocopier
Swtch on with pause key depressed and wait for the power and online leds blinks and error led off.
To cahnge from thertransfer or direct printing mode depress feed and pause spontaneoulsy.
By depresing feed the self test is printed
Oct 06, 2011 | Toshiba TEC B-452 Thermal Label Printer
Blower not working on 1997 chevy blazer
Check the blower motor relay, usually located under the hood in a box, also check the fuse in the fuse panel for the blower motor. If both of those are good then you have a bad blower motor.
Mar 17, 2011 | 1997 Chevrolet Blazer
Nokia phone 3100
following this instruction,
1.remove the white rubber ontop the power botton.
2.find a metal that can touch both edges of the tip where the power botton was removed from (positive -positive).
3.your phone will come on then you can enjoy your phone without switch botton.
Jan 11, 2010 | Nokia 3100
Ford f150 xlt 4x wont engage
Soledoid at transfer case unpluged or defective on board swith..Check contacts with voltage tester at switch first... power in? power when swtch on? Go to soledoid under veh. at case
Oct 31, 2009 | 1997 Ford F150 Regular Cab
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
What is it?
that means you have an aftermarket alarm previously installed have it remove from the car or try to find the swtch under the dash to unarm the alarm manually
all you have to do is locate the swtch and whit the ignition on turn the swicch ones and that's it the switch must to be small some where under the dash but if you can't find it just have some autorepair remove your ald alarm system
Jun 10, 2008 | 1997 Honda Civic
Toshiba 42H81 42" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
