Question about Mitsubishi WS-55809 55" Rear Projection Television
Ws 55809 with a 2,1 error code. machine has been flickering green screen more frequenly. not you turn it on get white screen then it shuts off. is this nachine repairable? please help.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2,1 IS x-ray protection, problem is either in the High Voltage circuit or with one of the three picture tubes.
It should be repairable but most likely a shop job.
SD TECH
Posted on Oct 01, 2010
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
The picture flickers occasionally. I am wondering if the bulb is going.
The WS-55809 is a rear projection TV and does not have a bulb, it has 3 picture tubes. DLP and LCD Projection sets have bulbs, or mercury vapor lamps. Does your picture flicker equally with different inputs?
Sep 26, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Power went out and tv wont turn back on. all i get is a blinking green light next to the on button
There is usualy one of two reasons. 1) The DM board has failed. 2) The convergence has shorted and is causing the TV to shut down. Normaly if its just a fast blink its the DM. If its blinking a pattern or error code of 22 its convergence. On the site www.TvRepairKits.com you can find out how to get the error codes and also the parts.
Dec 22, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Turns off immediately after turned on
Do the self check it should have: when shuts down and green light goes out: On the front of the set press and hold both input and menu buttons at the same time for at least 5 seconds and then release both.
Power light on set should blink a two digit error code: like 2 blink,2 blink, pause and repeat it at least 5 times total.
Let me know what error code and I will tell you what it means.
If this has helped you, rate this solution as I do this here for free.
SD TECH
Aug 15, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv shuts off when trying to turn on
Check the error code by holding the menu and device buttons for 5 seconds and reading the number of times the power led flashes between pauses. This has to be done after the set powers up and off.
2.2 is a common convergence problem.
Jul 05, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My HD 1080 WS-55809 won't turn on - little green light comes on for 2 - 3 seconds, then nothing. It was fine - we were watching a DVD but had it on pause - the tv turned itself off - then it won't turn...
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Mitsubishi WS-55809 55" Rear Projection...
The tv will come on for a split second then click and cut off its a mitsubusi projection ws-55809
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
SD TECH
May 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi ws-55809 power comes on and then goes off
try to check it again as these are the only codes for your model.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occurred.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
Mar 14, 2009 | Televison & Video
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
