Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
Is there a wiring diagram available other than the page that came with the timer?
  • 56 Answers
The one that is on the cover is the only one that is available. Maybe I could walk you through your question
Posted on Oct 01, 2010
Http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Page shows T-104 & T-101
Thing to know about T-101:
It cannot control 240V circuit
it is strictly 120V
Clock motor is 120V, load voltage poles are connected to clock poles, so load voltage must also be 120V
Wiring must be exactly as follows:
Hot wire must connect to pole 1 on T-101 or clock will not work, and timer will not work.
Black wire to Load must connect to pole 2
Neutral wires connect to pole A
How to test for Hot wire:
You have 4 wires in box. 2 white, 2 black
Hot wire should be black ... but code violations sometimes have people running white wire as Hot
Separate wires so you can test with ordinary tester.
Tape tester leads to wood sticks to keep hands away from voltage
Turn on power and test each wire to bare ground
When tester lights up, this is the Hot wire
Find Neutral wire:
Test Hot wire to each wire (excluding the ground)
When tester lights up, this is Neutral
Need to know simple wiring where power output pins are on eagle signal control off-delay timer #81Q2A605
1) Copy following link for general pin timer wiring:
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) Eagle tech support:
http://www.danaherspecialtyproducts.com/Eagle_Signal/Service_and_Support/Customer_Service___Tech_Support/
3) Fixya appears on 1st page of google search for this product, indicates there is no clear information available on the web.
4) Add a comment and describe the wiring diagram that appears on side of device.
Each pin timer has wiring diagram.
The image I found shows 11-pin base, and push button or impulse input connects to terminals 2 and 6. Image is not clear enough to determine more information.
Feb 20, 2013 | Hardware & Accessories
Can you show me paragon timer 4003-0 the wiring
1) Copy following links:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://waterheatertimer.org/images/Paragon-4000-series-wiring.jpg
2) 4003-0 is 120Volt timer so clock voltage is 120V
Timer can control 120V or 240V loads
Use diagram 3
3) Paragon is no longer making this timer or parts for timer.
If you purchased timer from ebay, then assume motor is bad or X2772 trippers are worn out.
Always buy new timers. Buy Intermatic and parts are easily available.
4) Replacement timer is Intermatic T101
Feb 16, 2013 | Paragon Hardware & Accessories
How do I connect my Jandy AE-TI heat pump to my intermatic T104P3
1) Copy following link for wiring illustration ... assuming timer is supposed to control pool pump:
http://waterheatertimer.org/images/T104-to-contactor.jpg
2) T104P is 240Volt (208-277V) SPDT timer in P plastic outdoor enclosure.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Jandy AE-TI is 208/230V pool heater.
http://www.bestbuypoolsupply.com/media/aemanual.pdf
4) Page 13 of Jandy manual shows single-phase residential wiring diagram.
5) First of all, power to main contactor is not interruped by timer, since this powers 24Volt transformer that controls the chip board and general operation.
6) The timer is connected to 'Auto-heat contactor.'
The confusion is what Load connects to this contactor? The water pump? Load is shown on diagram as 'pump time clock.'
I assume the load is the PUMP??
Dec 04, 2012 | Hardware & Accessories
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Need wiring diagram for RC2343TP intermatic
I cannot see the door panel wiring clearly from looking at Internet images.
Repost question with link to photo of door panel showing wiring diagram.
Otherwise, the nearest available drawing is in following manuals:
http://waterheatertimer.org/pdf/RC2403RT.pdf
http://waterheatertimer.org/pdf/RC2403RT-Door Label.pdf
Apr 27, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
The spring that turns off the power in my Intermatic WH21 timer is broken. Where can I buy a new spring?
Parts are not available for WH21 240V water heater timer.
Timer has 1 year limited warranty.
http://www.intermatic.com/customer%20service/frequently%20asked%20questions.aspx
WH21 is rated for 25Amps and works on water heaters up to 4500Watts.
Look at label on side of tank to see wattage.
WH21 is SPST and turns off one hot wire to water heater.
I ran a business for many years.
Cost of stocking, organizing, and shipping parts is near same cost as new timer.
Following page shows selection of replacement timers:
http://waterheatertimer.org/Boxtype.html
For example, I have tested WH40 and T104 and other timers that show on page.
Trippers and motors are available for Intermatic box timers WH40 and T104, so you can maintain these specific models for many years.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
WH40 and T104 timers are SPDT and turn off both hot wires to water heater.
Both timers will work on any wattage residential water heater
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
Feb 18, 2011 | Electric Intermatic Wh 21 Water Heater...
I need wiring diagram for Paragon 8154-20. The plastic board has melted
I think you have the 8145-20 240V
This is a time-initiated defrost timer
Paragon 8145 page
http://www.uni-line.com/modules/catalog/SearchResults.aspx?mode=productsearch&prodID=8145
Wiring for 8145
http://www.uni-line.com/images/docs/refrigeration-8140series-wiring.jpg
Wiring diagram shows both 120V and 240V
L1 L2 is 240V
L N is 120V
Website that explains defrost cycle
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 11, 2010 | Paragon 8145-20 Defrost Timer
Looking for wiring sequency
1) Intermatic has manuals for each product. Manuals have wiring diagram, but you have to identify product number. Look for product number and wiring diagram inside timer door.
2) If you know product number, and are still confused by wiring, then repost question providing as much information as possible. You also need to post what voltage wire you are putting timer on.
3) Here is link to manual page:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
4) Here is link to product page: for example sprinkler timer: Click on product number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Sep 18, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
648 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
