Question about Delphi SKYFi3 XM Radio Receiver
Problem with the Delphi SKYFi3 XM Radio Receiver UNIT LOCKED UP WILL NOT COME ON OR GO OFF
  • Delphi Expert
  • 509 Answers
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Posted on Oct 06, 2010
My skyfi3 is frozen on detecting sd card
Push VOL UP and PWR at the same time to RESET the radio.
Upload the latest firmware from ONLINE spot via Mini USB cable. Call Delphi on the phone for more info and details on how to get thiis unit to work better without locking-up as much..
Sep 06, 2010 | Delphi SKYFi3 XM Radio Receiver
My skyfi 3 I have in my car and home. It has locked up on a station and I can not turn it off or change stations. Whats the problem?
First: push VOL UP and POWER and hold both at the same time to RESET the unit. Then use the MiniUSB cable to load the latest firmware from the Delphi/XM radio website. If you still have an issue after the firmware update, then call Delphi directly for assistance.
Aug 29, 2010 | Delphi SKYFi3 Satellite Radio Receiver
My Delphi skyfi3 xm radio has stopped working, It seems to be in a freeze mode with the channel and signal strenth showing good but I am unable to command it to change. I have tried holding down the...
Hi
Hold down "power" and "volume up" at the same time to do a reset. You need a 'firmware update' from the Delphi website. Also, you can call Delphi for help too.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 20, 2010 | Delphi SKYFi3 XM Radio Receiver
My xm radio is all lit up it shows all of the information but you can't change channels get into the menu or any other functions it is like it is locked up. any suggestions
May 07, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi3 display blank. manual power only briefly...
try plugging the DC adapter directly into the buttom of the SKYFI3 - do you still get some sort of a power warning?
Jan 20, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
No audio through car radio
is your car radio and the xm receiver tuned to the same frequency?
Aug 31, 2009 | Delphi SKYFi XM Radio Receiver
Delphi SkyFi3 Battery WIll Not Hold Charge
You can buy a whole radio for as little as $30. I would even call XM and tell them you're going to cancel because your radio died, and they might sell you one if you guarantee to stay with them for a year?
Aug 02, 2009 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Receiver Logo
1,444 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
