Question about Acer (56.04145.901) (5604145901) Power Supply
Acer power f1 repair no screen connection - Acer (56.04145.901) (5604145901) Power Supply
  • Acer Master
  • 27,725 Answers
One bad lead can cause a computer lots of problems
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Oct 01, 2010
  • teejackson01 Oct 02, 2010
    thanks for respomce ill try it now
  • Brian Sullivan
    Brian Sullivan Oct 02, 2010
    also while you are doing this clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
    as dust will cause a lot of static which will make a computer overheat and cause lots of problems
    hope this helps
Acer 5532 powers on but the screen is black
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 20, 2012 | Acer Computers & Internet
My acer travelmate 5720 is not booting.. it showing white screen.. nothing s working.. if i press any button it says beep tone.. f1 key is also not working.. help me pls..
try to remove the battery from the laptop without the power chord connected ,then connected the power cord an on the laptop an then on it ,if it did not work try to remove the hard-disk from the back cover will have a sign mark of the hdd se wether this may solve the problem, if dosent the u have to visit the service centre ,also take care if it is under warranty then do not open the back cover or warry will avoide
Dec 07, 2010 | Acer Computers & Internet
How do i get to bios on my usb is switched on acer travelmate 220 to check if my
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses theCtrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 orCtrl+Alt+Esc keys to access BIOS.
Mar 07, 2010 | Acer TravelMate 2201LCi Notebook
My Acer Apsire 5100 will not power on properly. The acer screen (white and blue screen) will almost progress fully. Then, you hear two high pitched beeps and an error screen that says: "system bios...
Your operating system has been corrupted. At this point, you have to get all your information transferred onto another computer and then do a clean installation of the operating system of your choice.
Jan 18, 2010 | Acer Aspire 5100 Notebook
I have an Acer Power F1 and when I try to load Win XP I get the BSOD which proceeds to dump the memory. Win XP will not load in safe mode or last known config either, the XP window comes up but then goes...
if you have os cd then you can repair it by inserting it and going in recovery console or any of your friend have a pc where you can make a rescue disk by any means of anti-virus software you get .
Sep 11, 2009 | Acer Power F1 PC Desktop
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Screen won't turn on
plug to an external monitor and tell me what happened
Dec 14, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
