Question about Seagate 750GB ST3750640AS SATA300 16MB 7200RPM (Bare drive) Hard Drive
PC won't boot, Hard drive ticks out a beat
I installed a Seagate ST370640 750G HD last Oct. It's 30G short of full. Fragmented even. Worse, not backed up. Yesterday it locked while I was time shifting a TV programme, rebooted, Win XP came up normal, but froze after a while. Repeated this a few times, each time getting less further into the boot. eventually it only just got to a movable pointer on a black screen. I noticed HD activity. My Seagate was tapping out the beat, tick, tick, tick blank, repeatedly. So I disconnected it. My PC rebooted normally. Reconnected it, the problem returned. The HD is still under warranty, and if I ask my supplier to see if he can extract the data, it will void the warranty with no guarranty of success. Is my HD stuffed, am I snookered, any ideas.
MAS
  • Bootupblues May 29, 2008
    Guys, what do you think of this. Advise from a friend suggested that I download Seagate's DOSboot troubleshooting App. I loaded it onto a floppy disc and rebooted the PC. There are two tests, a short one, it failed straight away, another one called the "long test". It took three hours reading every byte on the disc. When completed, it reported nothing. So I ran the short test a second time which it passed in 2min. I ejected the floppy, and rebooted. The PC and HD came up with all data intact. Seagate's tutorial says that the long test checks for errored clusters and only if it finds any, will it prompt the user and ask what action it should take. It never prompted me or left any indication of errors in it's report. So unless it fixes the file tables without prompting I don't know what happened here. Needless to say, I really can't trust this piece of HW now so I am buying another 750G to backup what I've got as a minimum. Thanks for your offers of help.
    Problem Solver:
  • 27 Answers
Greetings...
:-[ best to not force the drive if you want the data recovered...
There are quite a few data recovery sites online... read the fine print... cost start at $300 or so and go up up up...
If the data is worth the money, best thing to do... sorry...
Ed
Posted on May 26, 2008
  • Ed Zirkle
    Ed Zirkle May 29, 2008
    Great... good to know you got it and that Seagate has that software... good luck...
    Sergeant:
    Champion:
  • 333 Answers
Lots of ideas!
Can you boot in safe mode?
Ihave a sagate 320 inturnal HD that was installed on my desktop Comp. 1.5 years ago I am getting window massage to download all my data due to the HD failing. I am looking at the date code and it appears...
It sounds as if the SMART measurements on your Seagate 320GB hard drive are triggering the Windows message advising that the drive is failing.
You would be best advised to backup your data from this drive to a different drive or on to DVD media (depending on how much data is involved).
To test the failing Seagate disk, download a copy of Hiren's Boot CD which is a CD image file (.ISO) and must be burnt to a blank CD disc - then boot the computer with the failing disk from this CD - then select DOS Programs on the initial menu, then choose Hard Disk Tools and then HDAT2 - this is a tool which will let you try to recover any bad sectors on your boot disk.
On the Hard Disk Tools menu there is also a SMARTUDM - HDD S.M.A.R.T. viewer which will let you examine exactly which areas of the Seagate disk are giving the problem leading to the failure message.
Jan 08, 2012 | Seagate Barracuda 7200.10 ST3160815A -...
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
Wd and Seagate usb hard drives attached to computer Will not boot when WD usb hd on Seagate makes no difference
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
Apr 22, 2009 | Western Digital My Book Essential Edition...
Changed HD know laptop wont come on
your hard drive has your operating system on it if you can't boot from your cd you may have to change your settings to do so.you can also back up and change one item at a time for instance put your original hard drive back in long enough to get the new monitor working then after making sure your system is set up to boot from the drive you will be loading your operating system from,change your hard drive again.At least this way you can narrow down what the problem may be.If not fix it.
Mar 16, 2009 | Computers & Internet
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
My internal hd sata seagate 1 terra is not recognizible any more
Domez,
Try Testdisk to see if it can restore the boot sector.
Chappo07
Sep 15, 2017 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Seagate SATA 160 GB (ST3160827AS) fried!
Are the logic board model numbers the same? How about year and batch manufature? check on that.
Sep 20, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate 750GB ST3750640AS SATA300 16MB 7200RPM (Bare drive) Hard Drive Logo
297 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
