Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
I have a fan with two light locations on it ( one above the motor almost at the cieling and the other at the base of the fan/light) I have 5 wires white, black, blue, orange and green. on the fan I have connected the ground but have only white and black in my fixture box in the ceiling. There are two switches to control power to the fan and they meet at the fixture box. I think the blue should be connected to the hot line but I am not sure about the orange. Any assistance would be great! I have no instructions as I bought the fan in a second hand store. thanks
    Novelist:
  • 116 Answers
You should be able to trace the wires from the top of the fan and find where they go. Of course you should have green, black, and white in the fan and yes the blue should be for the light. some fans with dual lights will both be controlled by the blue wire, and some will have a separate, so it is very possible it is the orange. If you can't follow the wire into and through the fan and light kit you may just have to "experiment". You said there are "2" switches that control the fan, and they meet at the fixture box? If there are two switches then you will have two hot wires, usually one black and one red (but it could be two black), but you said your fixture box only has black and white. (unless you have 2 black and didn't mention that, then most likely the other switch is for another light, or wall outlet. You may need to trace this to find out for sure. If you have separate switches for the light and fan, then Great! you can hook the fan to one and the lights to the other. Otherwise you'll have to hook fan and light both to the one switch and control them with pull chains. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 02, 2010
  • 377 Answers
Under normal wiring policy: White - circuit neutral (can be coded for a power line by colored tape at both ends) Green - equipment ground (can be coded for a power line by colored tape at both ends, but should be avoided) Black - Power Other colors - can also be used as power (Blue, Orange)
One switch controls the fan One switch controls the lights
POSSIBLE WIRING LAYOUT FOR THIS CIRCUIT assuming the power into the ceiling box is via the black wire that has to then be taken to the switches and back to the ceiling fixture.
The power comes into the ceiling box via the black wire from a power source, the white wire being circuit neutral. Orange wire - connects to black wire and takes power down to the switches. Blue wire - brings power from one switch to the fan. Green wire - SHOULD BE EQUIPMENT GROUND - but may be used to bring power from the switch up to the lights; tape should indicate it is being used for something other than equipment ground.
I would first keep all wires disconnected and at the ceiling box note which wire, if any, is connected to the black wire. With the switches off, check to see if there is power at the black wire. If there is power on the black wire and it is spliced to another wire, this other wire (Orange??) will probably be taking the power down to the switches. NOTE - If you have a black wire spliced to a black wire in the ceiling box and it appears one is taking power to the switches, then most likely the switches will control power on the Orange and Blue wires going into the ceiling box and the Green wire will be equipment ground.
By checking the switches and which wires they control voltage to, you should be able to wire the switches to control both the fan and lights independently, but both sets of lights will be on or off at the same time.
ALL POSSIBLE CAUTION SHOULD BE OBSERVED IN DOING THIS WORK AND IF YOU ARE NOT COMFORTABLE WITH WORKING WITH ELECTRICITY, FIND A QUALIFIED ELECTRICIAN TO DO THE WORK. ALSO - CEILING FIXTURES/BOXES THAT HOLD CEILING FANS HAVE TO BE OF AN APPROVED TYPE THAT WILL HOLD THE WEIGHT OF THE FAN/LIGHT COMBINATION AND MOST MUNICIPALITIES REQUIRE A PERMIT TO HANG CEILING FANS.
This may be a great deal for a do-it-yourselfer to understand if they do not have wiring experience, please feel free to contact me if you need additional clarification. IF YOU ARE NOT COMFORTABLE DOING THIS WORK, FIND A LICENSED ELECTRICIAN!!!!!!!
  • pwillitz Oct 02, 2010
    webdybird1- My sincere apologies! I viewed your question from a house wiring approach and not as wiring within the fan/light unit and I can see how this would definitely lead to confusion.
    PLEASE disregard my solution!!
    Too many nights with a sleepless baby.
    Paul
Price-on--mod-35022-kichler-cieling-fan-and-light
Best way is to contact manufacture for dealer location
Feb 15, 2015 | Kichler Lighting Dryers
How to fix a wobbly ceilng fan
wobbly cieling fan
1. make sure all mounting screws between the fan and the ceiling are tight. There is probably an electrical box mounted in the cieling that the fan is screwed into. I would turn the fan light on and then keep flipping breakers off, on at a time ,to see which breaker turns off the fan light. leave the fan light breaker off and you can unmount the fan from the cieling electrical box. The electrical box may have several holes in it for mounting screws and prehaps there are some holes left empty in the box that you can put more wood screws into to help keep the electrical box more firmly mounted and that may help lessen the wobble.
Its ok to bend the electrical wiring aside to put more screws in. Just be reasonably gentle with the wiring and then bend it back somewhat to where it was before you started. make sure that wiring does not get pinched between the fan and the electrical box and that all wiring resides inside the box.
#2 This is harder to do. you need to balance the blades for the fan ,similar to how a lawnmower blade is balanced after sharpening and before remounting the lawnmower blade on the mower. also kinda like balancing a car tire. I have a lawnmower blade balancing fixture that i bought at the lawnmower shop, but i dont know if there is a fan blade balancing fixture that you could buy from somewheres. Maybe try google.com,bing.com or ask.com and type into the search box fan blade balancer
or fan blade balancing fixture or fan blade balancing jig.
PLEASE read the directions or SPECIFICATIONS before you buy the fan blade balancer, only to find out that it only fits 9 inch diameter fan blades, and your blade is 2 4or 36 inches long.
The balancer may have to fit a certain diameter hole at the center
of the fan blade. When you finally find out which side of the fan blade is heavy, you have to grind , with an electric grinding wheel, some material off the heavy side of the blade so that it is the same wieght as the light side of the blade.
Try to imagine a cone shaped center[like step drills] like the capital letter V ,only up side down, so that the point is up. ON the underside of the inverted V is a needle tiped post that upside down V can pivot in any direction on. The hole in the middle of a lawnmower blade is centered somewheres on the outside of the inverted V, depending on the diameter of the hole in the lawnmower blade. The heavy side of the mower blade will go down and may touch the level asphault or the table top, depending on where you placed the balancing fixture. THen i would grind off metal until the heavy side can up to be level with the light side of the mower blade and it was considered balanced.
an appliance repair parts store may sell fan balancers, but if the would fit your cieling fan, better ask before you waiste your money on something that wont work for what you want.
Try calling up customer service of the manufacturor of your ceiling fan and ask about repair service for your brand fan.
see what repair service has to say, im sure many others have asked them about wobbling fans.
so they should have all the answers down pat.
Two more thoughts.
1.
.MAKE SURE ALL SCREWS THAT HOLD FAN BLADES ON TO THE HUB ARE THERE AND are TIGHT. one loose fan blade mounting screw or one missing fan blade screw will unbalance the whole thing and cause wobble.
2. the fan motor shaft bearing could be worn out or round or even egg shaped. If this is the cause, the motor must be diaassembled and new fan shaft bearings installed or the fan motor must be replaced.
good luck and have fun!
Sep 22, 2013 | Hampton Bay 24002 Ceiling Fan
The fan doesnt work
and nothing is there a fan motor available.
Did you mean " and nowheres is their a fan motor available"???
THat leaves you with 4 options.
1. prehaps the switch to the fan is not giving the fan any electricity when you turn the switch 'on'
2. prehaps there is a bad wiring connection to the fan and the repair is as simple as fixing the supply wiring.
You need to make sure that the fan is getting electricity before saying ,I have a bad motor. You could have a bad on/off switch or wiring to the switch or to the fan.
if you do have electricity going into the fan motor.
1. disassemble , repair, and reassemble the fan motor. That assumes that you can get repair parts and already know how to fix cieling fan motors or can even find a ceiling fan repairman.
I think cieling fan repair is a decesed industry[the job died because of lack of customers] like tv repair and microwave repaair,dead professions.
Many things from china are made as one shots[if they done work on the first shot,they never will because there are no replacement parts available in the usa. You have to fly to china to buy parts.
2. buy a new cieling fan from amazon.com
Mar 02, 2013 | Hampton Bay 24002 Ceiling Fan
How to install the ceiling fan, asahi brand, i just want to know how to install my ceiling fan without any technechians help
If one switch works fan and light put the black wire and the blue wire together on the fan and connect to black wire coming from cieling and connect white wire from fan to white wire from ceilling
Jun 21, 2011 | Heating & Cooling
Remove ceiling cover plate of Hampton Bay Antigua. This is the model that does NOT have srews on the outside of the coverplate that you loosen before turning. We've tried everything. Left, right.... You...
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical tape.at the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
look carefully there are screws somtimes with a grommet or paint as these were built in factorys all over the world and are very inconsistent if you rrally cant find screws and it will twist it is always left
left is loose right is tight
lefty loosy righty tighty lol
my grandad taught me that one i always remember
Feb 26, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
I have a hampton bay ac 552 cieling fan and the owner cut the wires,what wires goes to the fan and what goes to the lig hts.,black,white are coming from cieling in the fan above lighting wires...
Hampton Bay makes fans for HomeDepot. I would check with them or call 1(800) 654-0688 to try to get the information from the fan manufacturer. You need to find the UPC number which is located on a label on the top of the fan(body). I had a hard time making the numbers, but gat a camera and took a close up picture, but your is probably not mounted. The HomeDepot will help you find out the maker of your fan.(they have many makers so it is important to have the UPC no.)
Aug 02, 2010 | Hampton Bay Dryers
The correct why to wire up a cieling fan
The usuall wiring for a ceiling fan is black to black, white to white , and red house wire to the other fan wire, sometimes blue. If you only have two wires from the ceiling, then it is still white to white and black to black, but add the other fan wire to the black wires ..
Jun 17, 2010 | Solar 2-wire Pull Chain Light Switch For...
How do I get my hampton bay antigua fan down from the ceiling
Jul 30, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
I need to remove my hampton bay ceiling fan from the ceiling.
im trying to install light to ceiling fan but the wires are a different color and light wont come on
Jan 15, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
52 in. redington III cieling fan
Did you have to wire in the remote? If so you prob hooked up the light to constant power source. more info on number of wires on remote unit and wires on ceiling fan pls.
Dec 11, 2007 | Hunter 52" Ceiling Fan With Light And...
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
108 people viewed this question
Top Westwind Dryers Experts
Dan Webster
Dan Webster
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
