If the lever for the presser foot on your Kenmore 158.441 sewing machine is locked in the down position, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
Check the presser foot: Make sure the presser foot is properly installed and aligned on the machine. If the presser foot is not properly installed or aligned, it can cause the lever to become stuck in the down position.
Check the presser foot lever: Inspect the presser foot lever for any visible damage or looseness. Make sure the lever is not bent or broken and that it is properly aligned and connected to the machine.
Check the threading: Make sure the machine is properly threaded. If the thread is not correctly aligned or tensioned, it can cause the presser foot lever to become stuck in the down position.
Check for any other visible issues: Inspect the machine and its components for any visible issues that may be causing the presser foot lever to become stuck in the down position. This can include debris or foreign objects that may have gotten stuck in the machine, or damage to the machine or its components.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the machine serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
It is unlikely that you needed to go very far with the tear down. You are brave. Put it back together and take it in for servicing.
Why is my presser foot lever loose?
The presser foot lever is very loose and not moving the bar (foot lever). There is probably either an adjustment not set correctly or a screw that needs adjusting or replacing.
If the presser foot isn't connected to the presser foot shank, place the foot under the center of the shank. Lower the presser foot lifter making sure that the shank goes over the presser foot pin. Press down firmly on the screw that holds the presser foot shank until you hear the foot snap into the shank. Do not turn the presser foot shank screw. See the pictures on page 9 of the manual (page 11 of the PDF). Manuals LIb has this page here https://www.manualslib.com/manual/470415/Singer-7033.html?page=11#manual . The manual is also available from Singer on their support page: https://www.singer.com/support . The direct link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%207029_7033_%207035%20and%209410%20Sewing%20Machine.pdf . For feet that are attached to the slant shank, you loosen the presser foot shank screw. Place the shank over the presser foot screw and then tighten the screw to hold the presser foot. If you removed a foot and the shank together, put it back on. Make sure that the needle and the presser foot lifter are in their highest positions. Push up the front side (toe) of the presser foot until the foot snaps off the shank.
If the presser foot doesn't snap into place, make sure that you have everything aligned properly. Otherwise check for damage to the presser foot and the shank. Replace any damaged parts. Some presser feet are available here: https://www.sewingpartsonline.com/singer-7033-sewing-machine-parts.aspx .
There may be a disconnection between the lever and the presser foot bar. Perhaps a screw has fallen out, broken, or is loose? May need to take it for service.
Very common thing because the presser bar is always very tight in the housing, all you need to do is put some easing oil or wd40 on the bar and physically move the bar up and down and it will free off
I think you have to position the new presser foot under the shank then drop the presser foot lever down as if you were beginning to sew. This should snap the new presser foot right on. Be sure the little bar is positioned under the hook.
Had the same problem. Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
