Question about Garmin nuvi 250W GPS Receiver
I just bought my gps but i dont know how you turn on it on? and what is the circle disk for?and where should i connect the handle at? i dont get it...
  • 504 Answers
The unit has a slide switch on the side. If you are asking how to mount the unit, it came with a bracket that snaps on (there are indentations in top and bottom where it hooks in). Then you pop the ball mount into the receptacle on the back. The circle disc to which you refer is for PERMANENT dash mounting. It has double sided tape that sticks to the dash. You can then use the suction mount on the disc instead of the windshield. I hope this helps.
Posted on Oct 02, 2010
TomTom 910 freeze, long turn on
It is possible that the map data(base) and/or the navigation software is corrupted.
Have you tried running a (fix) disk utility against your (internal or external) storage disk for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 26, 2013 | Tomtom GO 910 GPS Receiver
My tomtom is connecting fine to the computer, but once I get the pop up window saying my device is safe to properly disconnect and I disconnect it and try to turn it on without it being hooked up to the...
If you have a big red circle with a white X in it, it usually means that your TomTom One 'disk' is corrupted: first try a 'hard reset' , while the power is on, stick a small (tooth) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressur on the stick will cause a complete system reboot if possible.
Next, since you can connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
If there is an error or you cannot reboot, hopefully you have a backup made either by copying the whole unit disk content or more traditionally via TomTom Home, I would suggest a complete restore your device content follow by a TomTom Home device update.
Hope it helps: let me know how you go.
Jan 05, 2010 | Tomtom ONE XL GPS
G. E. crock pot broken lid handle
i broke me g.e. crock pot lid, i need to find a new one but dont know how!! heeelp!! all the websites just go into circles!
Oct 22, 2009 | GE Crock Pots & Slow Cookers
I cant unlock my garmin nuvi 200.
if you bought a locked satnav without a code you are either very stupid or handling stolen goods. And dont give the **** that you didnt realise or didnt check. No-one in their right minds buys a satnav without seeing it working.
If you still claim its legit then send it off to Garmin and they offer an unlocking service
Oct 08, 2009 | Garmin StreetPilot c340 GPS Receiver
Pin number dont know it how to deactivated it
Correct. When setting the PIN the user is warned to either remember it or the secret location where it was set - as the GPS will unlock there. This renders a stolen GPS useless.
Sep 02, 2009 | Garmin StreetPilot c550 GPS Receiver
Tom tom go 700
Can be sofware problem or internal memory.
try to conect to pc if you see the dataa from the tomtom is just software if not can be from memory,if you dont know how just send it to a repair centre.
\try this www.satnavservice.com
Aug 29, 2009 | Tomtom GO 930 GPS Receiver
Magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...877f33f.jpg
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
Jun 02, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Tomtom 910 RDS-TMC Traffic Receiver
because tom tom uses the bluetooth connection via your cell phone to obtain traffic conditions on the newer verision of tomtoms they use the rds signals
Dec 11, 2008 | Tomtom GO 910 GPS Receiver
Dont know how to off my ipod classic 80gb......
To turn your your ipod off, hold the pause button (button on bottom of scroll circle) for three seconds.
Oct 31, 2008 | Apple iPod classic MP3 Player
Garmin nuvi 250W GPS Receiver Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
