Question about Vacuums
Sew- Prow Sewing machine Model ZZ- 401 need diagram to order part and manual. Has broken missing parts in spool area spool wont stay in under needle Davy B
  • David Baisa Oct 07, 2010
    Sew Pro 401 is a odd brand an el cheapo sewing machine. buy used new is easty parts are the challenge. I need a picture of the bobin spindle.
    President:
  • 1,796 Answers
Hi!!
Try this sites Hi!
It seems that this is a common problem for this machine. I think you will be better off getting a new machine for $50 at this site http://portablesewingmachines.ibuycheap.us/1_1063498_B0000DBJ2O_SewPro-ZZ-401-Portable-Zig-Zag-Sewing-Machine.html and leave the current for parts. OR, visit this sites to find your manual and broken parts. http://ifixmachines.com/Product-search.html?keyword=sew+pro&search=search
http://www.sewingguide.de/
http://www.sewingpartsonline.com/
Good Luck!!
Posted on Oct 01, 2010
What is wrong with my singer sewing machine model 6233?
That may be a relay inside going bad. Sounds
like a small part heats up too much, then it
needs to cool down to function again.
May 31, 2014 | SewShop.com Singer Model 6233 Instruction...
How can i do reset to my sewing machine?
It sounds as though something is caught or not put in correctly. Make certain that the thread is coming off the spool smoothly. You didn't mention if you can sew while it is beeping. Check your manual or contact any Singer sales center to question the beeping.
Dec 23, 2013 | SewShop.com Singer Model 7446 Instruction...
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
I just got a new machine (new to me anyway) new home hf106 model. i need to thread the bobbin on the new thead i am using and am not sure where to put the empty bobbin and how to thread it. help!
Janome New Home?
Unfortunately, Janome doesn't put the manuals for older machines on their website. Your best bet is to contact your local Janome sewing machine dealer and ask for a "copy" of the manual from them. A photo copy should be sufficient for your purposes. Otherwise I understand you'll have to buy a manual and wait to have it shipped.
But carefully look at your New Home. On the top toward the right there should be a fitting that looks like the bottom half of a spool. and next to it is a thing that almost looks like a mushroom.
Put the spool of thread on the spool holder, run the tread to and around the tension discs on top then thread the end through the hole in your empty bobbin. Place the bobbin on the thing that looks like a half a spool and push the whole thing to the right toward the "mushroom."
Press start, or hit the foot feed. Wind slowly for best results.
When full, stop and move the bobbin winder back to the Left (sewing mode)
Now... hold your bobbin between your right thumb and fore finger... pull the thread a few inches... your thread should be coming off the LEFT side of the spool, if not flip it over and try again. Open the bobbin area, drop it in with the thread coming off the left to the bobbin.
hold bobbin still with right index finger and with left hand slip the tread between the bobbin race's tension spring then if your model has a channel for the tread... follow it... otherwise pull straight back, replace the bobbin cover on the machine.....
Thread top thread then use the hand wheel to take up the bobbin thread.
(Of course this all assumes your New Home is similar to my janome or brother.) Have fun!
Be sure to get some good needles.... ;)
S
Mar 12, 2011 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
Tornado wide area commercial vacuum
Hi There,
Your Tornado Wide Area vacuum cleaner is actually manufacturered by Powr-Flite. The two companies are sister companies, and owned by the same parent company Tacony.
It sounds like to me that your belt may have broken, or fallen off of the motor shaft. This may explain why the roller brush is not spinning. There is also a reset switch on the machine, on the top (item # 41 in diagram below), you should check the reset switch first. Try pushing down on this switch to see if this will restart your brushes.
If it doesn't, here are instructions on how to open up the belt, and inspect it or replace it if it's broken:
If you need to purchase a new belt, you may contact Powr-Flite at 1-800-880-2913, and request them to send you part number 19802.
Here's links to the instruction manual, and parts diagram for your Tornado, which is the same exact machine as the Powr-Flite model PF2030:
Owners Manual & Parts Diagram
If you have any follow up questions, please don't hesitate to ask using the add a comment form here on the Fixya repair page. If you have any problems ordering from them directly, feel free to contact us, and we'd also be able to provide any parts for you.
Here's how you may contact us:
http://www.govacuum.com/info.html
Thank you,
Chris Jones
GoVacuum.com
Apr 16, 2010 | Tornado 93030 Wide Area Carpetkeeper...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
