Question about Dell Latitude D600 Notebook
Air card The slot that my air card plugs into is broken. Is there an adaptor that I can plug it into that will allow me to use a USB port
  • 426 Answers
Yes they are called usb network sticks
Posted on May 27, 2008
What is a wireless net adaptor
A device that adds wireless connectivity to a laptop or desktop computer. The adapter is typically an external module that plugs into a USB port. For desktop computers, the adapter may be on a PCI card, which requires opening the case and plugging the card into an empty slot.
Aug 03, 2014 | Computers & Internet
HP Desktop Modem broken ethernet port
Try to load the latest driver, you can get that from HP under your computer. If that does not fix it then go buy a cheap USB Ethernet adaptor from Amazon or BestBuy, plug it in to a spare USB port and follow the directions for the adaptor with your Ethernet cable plugged into the new adaptor.
That is it, you have bypassed the bad Ethernet power and can forget about it (they can't be fixed), you should be good to go.
If you don't want to try the driver, then just get a new adaptor and that will bypass the internal adaptor.
Good Luck
Mar 15, 2014 | HP Computers & Internet
Usb damage
If all the USB ports fail to function, then repairing them is difficult, as the problem will be with the USB controller on the motherboard. If one or two fail to work, but the other ones work, then you have the option of putting a USB extension port into the working USB socket and that will allow you to run several devices from the one port, or, depending on the laptop in question, you can get a USB adaptor PCIMCIA card or Cardbus card that will plug into the expansion slot on the laptop and will give you a more permanent USB solution.
For this to work, there must be at least ONE working USB port
Jul 21, 2011 | Computers & Internet
When putting the memory card into the slot, the screen reads 'memory card error'. Also, will not read the camera when plugged into USB socket. Please Help!
The camera port only supports USB-equipped digital cameras that support Pict-Bridge. If you attach a USB device that is not compactible digital camera (or Bluetooth adaptor) to the camera port, an error message appears on the color graphics display. If you have an older HP-brand digital camera, try using the USB that came with the camera. PLug it into the USB port on the back of the HP-all-in-one and not into the camera port near the memory card slots, This works with HP digital cameras only.
By default, Windows XP will format a memory card of 8 MB or less and 64 MB more with the FAT32 format, Digital cameras and other devices use the FAT (FAT 16 or FAT 12) format and cannot operate with a FAT32 formatted card. Either format your memory card in your camera or select FAT format to format your memory card in a Windows XP PC.
Hope this helps.
Thanks.
Have a good day.
Nov 30, 2009 | HP Photosmart 2610 All-In-One InkJet...
UBS port won't allow my memory stick to go in is there a lock on it???
Hello !
Be certain you are trying a USB port. It is rectangular in shape. The USB memory stick will only go in one way. Try flipping it over.
If still a problem ...
Either your USB memory stick is bad or your USB port on your notebook is bad.
Try another memory stick or try a different USB port on your notebook - should determine which is OK and which is bad.
Hope this helps.
Oct 28, 2009 | Acer Aspire One A150-1006 Notebook
I want to transfer DV footage from my camcorder to my laptop but do not have a fire wire port on my lap top, or a notebook adaptor slot - is there anything I can do?
several options. one is to transfer the material to your desktop then to the laptop. or you can go to radio shack and purchase an adaptor that will allow you to plug your sd card into a usb port. assuming, of course, that you use an sd card
Aug 08, 2009 | Video Cameras
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Usb port broken on my dell 3000 inspiron laptop
Don't know if there is such a adapter, but you can get a PCMCIA USB card.
You can also get a PCMCIA wireless card and these are available from Netgear, DLink and others.
Mar 05, 2009 | Dell Inspiron 2200 Notebook
I have a TP link wireless adaptor for an acer aspire T180 pc. I can't work out where to fit it on the motherboard
Providing the wireless adaptor is a PCI card this fits the white slot on motherboard.
Should it be USB, then plugs in the USB port.
Feb 22, 2009 | Acer Aspire™ T180 PC Desktop
Slot for memory card
I assume you are speaking of the USB port to plug the memory card reader into. Some systems have those ports on the front of the machine while others are on the back with the rest of the ports
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Dell Latitude D600 Notebook Logo
52 people viewed this question
Alun Cox
